Cool, Efficient, mag-lite by bravebaker
Replace the bulb in a 2xAA mag-lite with a bright white led. A cool burning led will give you longer battery life and won't burn your face off.
Step 1: Collect the parts
You'll need a 3.2 volt LED -- I think most bright white LEDs qualify. A ruler or caliper. An old, beat-up mag-lite, the kind that takes 2 AA batteries. Some wire cutters. A low speed or variable speed drill and 1/4" bit (not pictured). A small vice or pair of adjustable, locking (vice-grip style) pliers will come in handy (not pictured).
1-40 of 74Next »
botronics says: Sep 1, 2012. 2:34 PM
The only rechargeable 1.5 batteries are the rechargeable alkaline type. Nicad and NiMH are 1.2 volts (1.37v hot off the charger) and never 1.5 volts. If you have a rechargeable Nicad or NiMH marked "1.5v" show me a photo. I don't like the rechargeable alkaline because they leak.
COMMODORE64 says: Sep 7, 2012. 5:58 PM
that comment was retarded made at 4 years ago and we all knows im wrong about rechargable 1.5vs
come on shut your yap and move on!
botronics says: Sep 6, 2006. 5:11 PM
No current limiting resistor? How long has it been burning? Does it work with rechargables?
COMMODORE64 says: Apr 6, 2008. 6:30 PM
It says 2AA battery equal as 3V, and this LED is 3.2V, so nothing is bad. And yes, rechargable works too, because they works as 1.5V each.
severepb says: Dec 10, 2010. 4:58 PM
actually, 2 AA batteries brand new are about 1.6 to 1.7 v.
JamesRPatrick says: Jan 22, 2009. 7:42 PM
1.2v each, usually.
PerfectPantaloons says: Nov 4, 2010. 9:04 AM
every AA battery i have ever used was 1.5 V...
JamesRPatrick says: Nov 4, 2010. 9:36 AM
Rechargeable batteries are only generally 1.2V unless they say otherwise.
PerfectPantaloons says: Nov 4, 2010. 10:09 AM
i don't know i'm looking at my collection of batteries... (and i have a TON of AA's) and they all say that they are 1.5.... including the rechargeable ones.... what brand are you talking about???
ttaylor10 says: Aug 31, 2012. 8:24 PM
All my rechargable AA's say 1.2 V
Just my 2 cents.. Where did you get rechargables that are 1.5?
JamesRPatrick says: Nov 4, 2010. 2:28 PM
Rayovac, Radioshack, Sanyo, and a couple more generic Chinese brands that I have. If yours are newer and 1.5V, that's great, more compatability. But as of a few years ago when I bought my last ones, the standard seems to be 1.2V for rechargeable AA's.
PerfectPantaloons says: Nov 4, 2010. 6:42 PM
hmmm well then this is all news to me... this will be very helpful to me and my projects.... Thanks for the info
COMMODORE64 says: Jan 22, 2009. 8:11 PM
Sorry, You are right. Thanks for the correction.
Guardians38 says: Sep 15, 2009. 9:48 AM
I have GOT to make this... im going to buy a flash light just for this =)
marselsipod says: May 2, 2009. 6:57 PM
DAMN! i just got my free LEDs shipped and needed a way to test them, and thought of it in the bathroom, was all excited, but then i found this instructible. damnit! but kudos to you for thinking of it 3 years before me =P
Prometheus says: May 22, 2006. 8:58 PM
light output might actually be greater than the maglite bulb, depends on the led's mcd. If you find a "superbrite: white, the LED will make a laughingstock of the old bulb. Alternative to drilling out the focus (reflector), you can find the same ratings for ini's and sub-mini's that will fit without any modification except to the LED lead length. You will know a superbrite if it's hard to tolerate it shining directly into your eye, and perhaps leaves a bit of retinal burn.
Eirinn says: Jan 7, 2009. 5:50 AM
Pointing superbrite LEDs at your eyes can cause retina damage it's a very bad way to do it :)
phenoptix says: Oct 11, 2006. 8:08 AM
That's not the best way to test LEDs!!
Pwag says: Feb 21, 2012. 10:55 PM
These guys are right, use someone else's eyes.
phenoptix says: Mar 19, 2012. 6:53 PM
6 years for a reply to that comment Pwag! But it was worth it!!!
Pwag says: Mar 20, 2012. 11:36 AM
Ha! The internet is full of surprises some times!
Ashhow says: Sep 2, 2007. 6:12 AM
Can any one tell me if i could do this with my AAA mini maglite? i imagine it shouldas it still takes 2x1.5v cells
ironsmiter says: Nov 28, 2007. 7:12 PM
As long as it's a 2-battery flashlight, you should be able to use a bright white led. triple-a's you could just replace the bulb with the led, pop in fresh batteries, and have a nice bright light. As the voltage drops on your 2-cell flashlight though, the led will dim considerably. even with a double-A light, an incadescent bulb will still be dim but useful long after the LED is "dimmer than a politician". If you have a 3-4 battery flashlight, and use the proper resistor, you'll be good. Before anyone umps on me about that last statement... yes, on a fresh set of battries, a led conversion will outlast a normal bulb by many, many hours. The other cavet is, if you use rechargavble batteries, you'll only get 2.4 volt instead of 3volt. most bright white led's will barely be visible at that voltage, even though the amperage is plenty large enough. :-( Normal bulbs will only be slightly dimmer.
prometheus5500 says: Oct 12, 2007. 11:30 PM
now is this brighter? or is the only plus that it sucks less juice and lasts longer?
bravebaker (author) says: Oct 13, 2007. 6:32 AM
Depends on the LED. The one that I used is probably about a 1/3 as bright as the regular bulb, but here it is 18 months later and I still haven't changed the batteries. My kid uses it all the time and forgets to turn it off, so I know it was worth the (tiny) effort. :-)
macmaniac says: Jul 29, 2007. 6:23 AM
rapid electronics in the UK sell a white 5mm LED at 25,000mcd for just 56p!!
markcrosby says: Sep 17, 2007. 2:54 PM
I bought mine at Ledtronics out California. http://www.ledtronics.com/
Digital_Anarchy says: Aug 31, 2007. 3:14 PM
i love rapid!! my favourite place for components. much cheaper that maplin (uk equivalent of radioshack, think they can charge whatever they what just because they have no competators with highstreet (as opposed to online) shops (stores).)
Klowd_13 says: Aug 21, 2007. 2:02 PM
im not sure if you herd of it....but they make a LED conversion for the mini mag
vtsnaab says: Oct 22, 2006. 8:33 PM
A few words of warning about that vendor:
http://www.lck-led.com
I ordered from them - only about $13 worth of stuff, but I don't recommend using them.
They happily took my money, and almost a month and many emails later I finally got a
single reply from them admitting they had a system error and the order was never
processed or shipped, many weeks later it finally came, and was 1/2 wrong.
They don't answer emails and I am stuck with the wrong LEDs.
Since only 1/2 of my order is good, I actually paid 2x the cost of the ones they
got right...
There must be a better, domestic source that is better and as affordable.
erckgillis says: Dec 31, 2006. 9:11 AM
ranjeevm says: Nov 4, 2006. 7:00 PM
I have ordered 13000mCd white LEDs from eBay at about $21. Once they come in I plan to hook them up with a charger, NiMH battery set to wire up a few emergency lamps. Before I do that, I need to know how much of biasing current gets the best intensity of light without any damage to the LED. If I use 4 X 1.2V batteries, is a 10 ohm, 1W biasing resistor enough per LED? How much of light is 13000mCd, theoriticallt it should be like lighting 13 candles in a room! So is just 1 LED enough for a medium sised room? If it is, how many are really required for proper diffused lighting? If anyone here has any idea, this would save me a lot of browsing for data sheets and trial and errors...this would be really really appreciated. Guys, please look up my profile. If your knowledge helps me today, mine will help you tomorrow! Thanks!!
ranjeevm says: Nov 7, 2006. 11:55 AM
Surprised that no one has this info! Guys to be able to have optimum performance we must have this data (some of this I have been able to find through experimentation, now that the LEDs have arrived, but not all). Now some basics... 1 lumen = 1 candela (both are units of measurement of light flux density i.e. light intensity) For a flash light a 6V filament bulb typically has the output of 10-20 cd so using 2-3 LEDs each of about 13000mCd is good enough (I wouldnt be satisfied by just one LED if alloweed the luxury of some space for LED mounting. For other forms of portable lighting, for example a camping lentern, many more LEDs are needed(I just ordered a flash light with 36 LEDs from eBay just to see how intense that can really be! and I shall update you guys on that later) For indoor lighting the direct competitor of white LED are CFLs. I have compared all light sources in the table below: Note that there are LEDs that deliver upto 79L/W. Once these become readily available, LEDs should be everywhere. For now just remember that a typical LED has a voltage drop upto 4.0V and needs a biasing of upto 300mA. However not all white LEDs can handle that kind of current so be careful.
ranjeevm says: Nov 7, 2006. 10:22 PM
There is another 'discovery' that I made which I cannot resist mentioning here. 50000mCd white LEDs are available on eBay! Biasing current is merely 25mA! Vf-3.6V! What does this mean? Literally if the last column is divided by 22.22, you would get the wattage figures! On the whole LED are about 6 times more efficient than CFLs a staggering 30 times more efficient than filament ones!
erckgillis says: Dec 31, 2006. 9:07 AM
All this data is also avail for most LED's. Do go with 16, 32 or more LEDs.
Wide disbursed beams are not always brighter, cannot be "focused" and are usually power hungry...
See the 1w, 3w 5w and even 10watt LEDs with power curves, lumens and testing here...
http://www.flashlightreviews.com/reviews_index/reviews_index_ledbulbs.htm
Join our new LED Group!
http://www.instructables.com/group/deathbyled/
Wonko the sane says: Dec 7, 2006. 1:26 AM
Seen similar, even made one myself. I got the instructions for it from otherpower.com (_lighting_flashlites).
Clan X-Man says: Dec 3, 2006. 8:36 PM
Would this work with the larger rechargeable MagLites or would the power source be to much for the LED? I don't know much about these things is why I ask. X
Clan X-Man says: Dec 3, 2006. 8:34 PM
Very cool! Just signed up for the website tonight after finding it today. Saw this one found the parts around the house including old mini mag and voila! 10 minutes later and it works. Don't know if the LED is a super bright but it works fairly well. X
jaredforshey says: May 4, 2006. 7:47 PM
Yeah, you always need a resistor with an LED, even if the LED is made to drop the whole voltage. Once an LED is passing current, its resistance quickly tends toward zero. I = V/R, so current draw increases to the maximum that the source can provide. It will be terribly inefficient, and might burn out the LED to boot.
bravebaker (author) says: Nov 29, 2006. 8:12 AM
"Yeah, you always need a resistor with an LED"
I would have to say this statement is incorrect insofar as having to add more resistance in the form of a resistor. I got out the old multimeter last night and watched the current draw of the flashlight. It was around 30ma and stayed there for as long as I cared to watch it.
I'm willing to bet that Tazzz's comment about the internal guts of the flashlight providing a little resistance and the fact that I'm driving a 3.2v LED with <3.0 volts is what is keeping my LED intact.
1-40 of 74Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
