Introduction: Cool Anvil Stand
Picture of Cool Anvil Stand
I bought myself an old anvil. With the invaluable help and guidance of my brother Steve and his well equipped workshop we set about making a stand for it. I'm sure there's many ways to go, but here's how we did it.
What you need:
Cardboard template of your anvil. This way you can make sure everything is a perfect fit without having to lug the anvil around.
Timber. The widths we used are 195mm x 45 and 145mm x 45. We needed 7 pieces of each cut to the required lengths (see how to get this measurement below)
2 pieces of 240mm angle iron for the top edges
4 lengths of M12 threaded rod
8 M12 nuts (I went for brass domed nuts because they look cool)
8 large washers (I went for square)
2 wire tensioner hooks
2 carriage screws and washers to fit tensioners
length of chain
4 lengths of decking wood or similar to fit the base
screws to fit
2 heavy duty casters (optional)
Off we go!
Step 1: Cut!
Picture of Cut!
Decide on the best working height for your anvil. Some people say the height of your knuckles, some say the wrist. I am quite tall and liked the height of my kitchen worksurface so aimed for that.
Once you have this measurement, take away the height of your anvil (11" in my case). Cut your timber to this length.
Step 2: Drill
Picture of Drill
Put a wide piece and a narrow piece of timber next to each other and work out where the nuts and rods will go. You don't need to be exact, but it will look neater if you are. Mark and drill the first pieces to fit the threaded rod.
Step 3: Line Up
Picture of Line Up
Use the 2 drilled pieces of timber as a drill template for the next piece, remembering that we stagger the timber each time; wide and thin, thin and wide, wide and thin. Use clamps or guides to make sure you get these drill holes lined up correctly.
Step 4: Poke!
Picture of Poke!
Stack the timber in alternating widths and poke the threaded rods through. Put large washers on each end of each rod. Put the fancy domed nuts (if you're using them) on one side and temporarily use normal nuts on the other side to pull the whole structure together tightly. You can then cut the rods to the correct size. Replace the temp nuts with the fancy ones.
Step 5: Bottom!
Picture of Bottom!
Cut the decking or similar with a mitre to fit in the base. We used brass coach screws to match the brass nuts.
Step 6: Correction!
Picture of Correction!
We were a little bit sloppy in our work and failed to line up the timber perfectly before drilling so had to level the top and base with a set square, hand saw and sander.
Step 7: Wheels!
Picture of Wheels!
Stick the casters on the back in a fairly low position. We drilled and screwed through the casters' bases to ensure they could not swivel. We also stuck ours on a raised board.
Step 8: Grind
Picture of Grind
Attach the angle iron to the top of the stand on the same side as the nuts. This ensures that the timber all stays put when you start whacking the anvil. We cut it in place for ease. We recessed the angle iron to keep the top level, but it's not necessary.
Step 9: Chain
Picture of Chain
Put the piece of chain around the base of the anvil and use the chain tensioners to attach it firmly.
To be honest, the base is so sturdy, the anvil so heavy and my hammer blows so weedy that there is no way the anvil needs chaining down. But I think it looks great and is therefore vital.
Step 10: Unnecessary Frippery
Picture of Unnecessary Frippery
We had a large iron hinge laying about so we attached the female part to the base and the male part to a rod. We used these and a fine bit of leverage to wheel the base about. Utterly unnecessary, but there you go...
Step 11: Banging
Picture of Banging
Start banging!
Lorddrake (author)2017-08-28
an excellent job .. now if only the anvil fairy would bring me an anvil of my own I could totally copy your design :D
DIY Hacks and How Tos (author)2017-08-26
This is really cool. My wife has been wanting me to create an anvil setup for you. I might have to try it using this design.
About This Instructable
777views
18favorites
License:
More by LaurenceB23:Anvil Holdfast for Hardie HoleAdjustable Blacksmith Twist WrenchConvert a Punch to a Touchmark Stamp
Add instructable to:
