loading
OK, I'm going to assume that you already have batch experience and don't need me to explain every command and every symbol and every thing that is typed. So here we have four
different batch files. If you have no experience with batching, I suggest you try this tutorial:
http://www.instructables.com/id/Batch-Tutorial-Using-Batch/
I'll just wait here.
Step 1: Color Tester
Here is the code for testing colors. It's simple and it can be pretty useful.
@echo off
:test
help color
echo ----------------------------------------------------------
echo.
echo Type a color code to test colors.
echo To exit, just press the X.
set/p color=
color %color%
goto test
Step 2: Portals
In the zip. folder in the last step, I give you a portal that goes to instructables.com.
But here, I will show you a batch file that you can customize to go to multiple websites.
Here it is:
@echo off
color 0a
echo This is the site locater. Choose the # of the site you would like to go to.
echo 1= www.youtube.com
echo 2= www.facebook.com
echo 3= www.internet explorer.com
echo 4= www.firefox.com
echo 5= www.hulu.com
echo 6= www.netflix.com
echo.
set/p "number=-->"
if %number%==1 GOTO 1
if %number%==2 GOTO 2
if %number%==3 GOTO 3
if %number%==4 GOTO 4
if %number%==5 GOTO 5
if %number%==6 GOTO 6
:1
start www.youtube.com
goto end
:2
start www.facebook.com
goto end
:3
start www.internetexplorer.com
goto end
:4
start www.firefox.com
goto end
:5
start www.hulu.com
goto end
:6
start www.netflix.com
goto end
:end
You may replace the listed websites with any of your own if you want.
Step 3: Guessing Game
This is a guessing game I came up with.
I did not take some other guy's guessing game and make some changes.
This one is rather of its own design.
@echo off
color 0b
set/a one's=50
set/a two's=40
set/a three's=30
set/a four's=20
set/a five's=10
set/a six's=5
set/a seven's=1
echo Welcome to this useless two-player game in which one player picks a number
echo.
echo between 1 and 100 and the other player tries to guess it. Player 1 makes the
echo.
echo number and player 2 tries to guess it. You will be given NO hints or clues.
echo.
pause
cls
echo Enter the name for each player.
set/p "pone=Player one>"
echo.
set/p "ptwo=Player two>"
cls
goto ar
:busted
cls
echo I SAID a number between 1 and 100!
echo.
:ar
echo OK %ptwo%, look away. %pone%, type in the number and press enter.
set/p "deguess=>"
if %deguess% GTR 100 GOTO busted
cls
echo Choose a difficulty, %ptwo%:
echo.
echo (1) piece of cake-50 guesses
echo (2) easy-40 guesses
echo (3) moderate-30 guesses
echo (4) a little tricky-20 guesses
echo (5) hard-10 guesses
echo (6) insane-5 guesses
echo (7) impossible!-1 guess
echo.
echo Type the number of the difficulty you would like to play.
echo.
set/p "diff=>"
if %diff%==1 GOTO 1
if %diff%==2 GOTO 2
if %diff%==3 GOTO 3
if %diff%==4 GOTO 4
if %diff%==5 GOTO 5
if %diff%==6 GOTO 6
if %diff%==7 GOTO 7
:1
cls
goto br
:no21
cls
echo NOPE!
echo.
:br
echo Guess in the space below. You still have %one's% guesses.
set/p "guess41=>"
if %guess41%==%deguess% GOTO success
set/a one's=%one's%-1
if %one's%==0 GOTO failure
goto no21
:2
cls
goto cr
:no22
cls
echo NOPE!
echo.
:cr
echo Guess in the space below. You still have %two's% guesses.
set/p "guess42=>"
if %guess42%==%deguess% GOTO success
set/a two's=%two's%-1
if %two's%==0 GOTO failure
goto no22
:3
cls
goto dr
:no23
cls
echo NOPE!
echo.
:dr
echo Guess in the space below. You still have %three's% guesses.
set/p "guess43=>"
if %guess43%==%deguess% GOTO success
set/a three's=%three's%-1
if %three's%==0 GOTO failure
goto no23
:4
cls
goto er
:no24
cls
echo NOPE!
echo.
:er
echo Guess in the space below. You sill have %four's% guesses.
set/p "guess44=>"
if %guess44%==%deguess% GOTO success
set/a four's=%four's%-1
if %four's%==0 GOTO failure
goto no24
:5
cls
goto fr
:no25
cls
echo NOPE!
echo.
:fr
echo Guess in the space below. You still have %five's% guesses.
set/p "guess45=>"
if %guess45%==%deguess% GOTO success
set/a five's=%five's%-1
if %five's%==0 GOTO failure
goto no25
:6
cls
goto gr
:no26
cls
echo NOPE!
echo.
:gr
echo Guess in the space below. You have %six's% guesses left.
set/p "guess46=>"
if %guess46%==%deguess% GOTO success
set/a six's=%six's%-1
if %six's%==0 GOTO failure
goto no26
:7
cls
echo Guess in the space below. You only have %seven's% guess.
set/p "guess47=>"
if %guess47%==%deguess% GOTO success
goto failure
:success
cls
echo Well done, %ptwo%! You may now exit the game.
color 0c
color 09
color 0e
goto success
:failure
cls
echo %pone%'s number was too difficult. Sorry, %ptwo%.
echo.
echo The number was %deguess%.
echo.
pause
Step 4: Timer
A simple timer with a built-in calculator.
@echo off
:menu
color 0b
:bust
cls
echo Welcome to the timer. This timer only counts seconds.
echo.
echo Type in the amount of seconds to count. The number may range from 0 to
echo 99,999. If you need help converting minutes into seconds, type c for a
echo caculator.
echo.
set/p "time=>"
if %time%==c GOTO calc
if %time%==C GOTO calc
if %time% GTR 99999 GOTO bust
cls
echo The time has been set! Press any key to start counting. You can stop the
echo timer by pressing any key. After stoping, the timer cannot continue.
echo.
pause
cls
color 0c
timeout %time%
echo.
echo (DING!)
echo.
pause
goto menu
:calc
cls
color 0a
echo Type the math problem below. This calculator doesn't accept decimals,
echo percents, etc. Only whole numbers.
echo.
set/p "math=>"
set/a nmath=%math%
cls
echo %math%=%nmath%
pause
cls
echo Would you like to return to the timer or use the calculator again?
echo.
echo c or C= calculator
echo t or T= timer
echo.
set/p "route=>"
if %route%==c GOTO calc
if %route%==C GOTO calc
if %route%==t GOTO menu
if %route%==T GOTO menu
P.S.
If anyone knows how, I'd like to know how to make some noise sound out when the timer
goes off. But only for a short time. I don't want to have it go on infinitely, because that would mean restarting the computer every time I use the timer.
Step 5: Download
Thanks for coming!!!
Here's the download.
<p>you can put like :</p><p>start c:\music\&quot;any song.mp3&quot;</p><p>at the end</p>
<p>i did it </p>
<p>look here</p><p><a href="http://www.instructables.com/member/Batchcc?show=INSTRUCTABLES" rel="nofollow">http://www.instructables.com/member/Batchcc?show=I...</a></p><p>Full screen matrix to !!</p>
<p>Holy. Crap. Thank you for posting the exact code, because I'm an idoit and cant figure this out. You, sir, are the best.</p>
I know that it's not exactly a ding, but using Ctrl + G in batch causes a beep of sorts.
I think to do that you would have to replace the URLs with the document adress. Like for Windows you would do C:\Users\Person\Desktop\Programs <br>Thats my best guess.
Type this to make the ding sound (put this after echo (DING!): <br> <br>rem Making the temp file <br> :num <br> if exist temp%num%.vbs goto num <br> echo ' &gt; &quot;temp%num%.vbs&quot; <br> echo set speech = Wscript.CreateObject(&quot;SAPI.spVoice&quot;) &gt;&gt; &quot;temp%num%.vbs&quot; <br> echo speech.speak &quot;Ding!&quot; &gt;&gt; &quot;temp%num%.vbs&quot; <br> start temp%num%.vbs <br> pause <br> del temp%num%.vbs <br> pause
if u want to make the ding sound click on the bit where it says ding &amp; press Ctrl + Shift + G
Dude you are awesome do you have a youtube account making this ? <br>
In the part of the script where it says ding, press Ctrl+Shift+G and it should print a character that says BEL, highlited black. When you run it again, it will sound the system bell. you can also type this into cmd. Depending on the text editor u use, it may show it or not. I use Notepad++. Here is a list of other special commands(if you type them into cmd, most of the print out a character, such as a heart of spade.): <br> <br> ~ Shift + Esc = (ESC) <br> ~ Ctrl + E = (ENQ) <br> ~ Ctrl + R = (DC2) <br> ~ Ctrl + Pause\Break = (ETX) <br>&Acirc;&Acirc; ~ Ctrl + Shift + Y = (EM) <br> ~ Ctrl + Shift + W = (ETB) <br> ~ Ctrl + Shift + O = (SI) <br> ~ Ctrl + Shift + A = (SOH) <br> ~ Ctrl + Shift + D = (EOT) <br> ~ Ctrl + Shift + G = (BEL) <br> ~ Ctrl + Shift + H = (BS) <br> ~ Ctrl + Shift + Z = (SUB) <br> ~ Ctrl + Shift + X = (CAN) <br> ~ Ctrl + Shift + C = (ETX) <br> ~ Ctrl + Shift + v = (SYN) <br> ~ Ctrl + Shift + B = (STX) <br> ~ Ctrl + Shift + N = (SO) <br> ~ Ctrl + Shift + 6 + (RS) <br> ~ Ctrl + Shift + -(Dash) = (US) <br> <br>You may not be able to seem them up here, but the characters look like the ones in parenthesis ieg. (SUB), (BEL) <br>On some text editors, it they will show up like symbols. Note that these characters cannot be copied and pasted.
if you want to make a sound go off for a timer what you could do is have an audio recording of a DING! sound or whatever. The you could use the START command to start the audio file, then to end the sound i am sure there is a close window command. However, i do not know of it because i have never had to use it. This would make it much more difficult to get off the internet though. You would have to compact the audio file into same folder as the batch file. Possibly you could variate the locker batch file that can be found online. This batch file hides things on the desk top until it is unlocked. You could variate that into your batch file so that it requires no password and only appears for a short time. thus you would be able to call upon an audio file that, in theory, be saved to the desktop.<br>if you have any questions or need the locker batch file email me at noah.hepworth@hotmail.com
@hwalker4<br><br>to open the file you cant just put:<br><br>&quot;C:\test.txt&quot;<br><br>you need:<br><br>start &quot;C:\test.txt&quot;<br><br>or to open a *.bat<br><br>call file.bat
yeah you could easily e.g<br>@echo off<br>cls<br>C:\file.txt<br><br>would open file.txt or..<br><br>just typing the file name should work
ok thanks
nice could i use it to acess folders and keep documents
I don't know how, but you probably could.<br>
wow got to do it
About This Instructable
127,118views
28favorites
License:
More by jklujm:My Herringbone Gear Cool Batch Files Batch Tutorial Using Batch
Add instructable to:
