Remove these ads by
Signing UpStep 1Flip screen
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
This isn't useful.
L
http://wiki.answers.com/Q/Why_can't_you_create_a_folder_named_CON_in_Windows_or_MS-DOS
hope this helps
all this change does is affect windows and how it delays the loading of menus for normal windows etc.
If you want to read a little more on this hack please read below.
http://www.pctools.com/guides/registry/detail/17/
the only guaranteed way to increase the performance of your PC is to upgrade the hardware within it, the best and normally cheapest speed increase you can get is to upgrade the RAM (Physical Memory) in the PC, if the PC is not that old i.e. less than three years consider upgrading the RAM to the maximum amount it will take.
failing that a good old fashioned CPU upgrade will help to increase the performance, not to mention regular maintenance like Disk Defrag, clearing out temporary files, etc. your local PC shop will be able to advise you the best on any upgrades you may need.
None of your 'tricks' has to do with the CPU (the Central Processing Unit). They all are related to the operation system - Windows in your case (and XP I guess based on the registry trick).
1) Will only work if there is a background program looking for those key code. On some laptops/notebooks such programs are installed.
3) Will only speed up the showing of some menus. No speed up for CPU or anything else, sorry.
4) That's a leftover from good old DOS times. CON is the (reserved) name of the console-device. For similar reasons, you cant have a file named NUL, COM1, COM2.. LPT1, LPT2 etc.
8) Yep, that saved me when suddenly 8 keys stopped working on my netbook keyboard halfway through a trip in Africa.
Again, some nice tricks (I liked the Star Wars 'movie' when I found it first ... some five years ago) but none of them is a CPU trick.
