3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cool Little Miniature Stove!
Step 2Sand the cans
Sand the cans
Sand the paint off the bottom couple of inches of both cans.
Make it as smooth as possible to ensure a tight fit and prevent leaks.
You'll need to empty one of the cans, so go ahead and have a drink while you work on the second one. The second one needs to be full and sealed, so don't drink it yet!
4 comments
Jan 27, 2012. 8:06 PMMattBothell says:
To sand mine I put my hand sander in a vice and used 220 grit paper worked like a charm
Sep 12, 2009. 4:06 PMiheart7s says:
use a heavy wire brush... the kind you use for cleaning a grill... you can have it sanded completely in under 45 seconds with a little practice! =D
Jul 8, 2009. 4:01 PMethanbkr says:
try an aluminum oxide paper its better for metal work
May 11, 2009. 8:05 PMsuperitchy says:
I'm having issues sanding my can; I took thirty minutes and still have about a third of the label visible.
Jun 28, 2009. 4:59 PMhydrnium.h2 says:
I used 600 grit and sanded the can while running it under water, it cleaned the can it about 5 minutes, that is, with me using alot of pressure and rapid movement (back and forth) to get the sandpaper to really dig into the paint.
May 14, 2009. 6:10 PMnrepak says:
use a sanding bit on a dremel
May 12, 2009. 6:37 AMShut Up Now says:
maybe a coarser grain?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
96
Author:NK5
