3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cool Little Miniature Stove!
Step 3Cut the cans
Cut the cans
  • last photo ←
You need to cut the bottom inch or so off of the first can.
The cut needs to be almost perfectly even, so use a book to hold the blade while you press the can up against it and spin. You can also nail the blade to a block of wood.
Spin the can slowly while pressing against the blade, making sure not to dent the can in the process. It will take about 10 to 20 turns to cut through it enough to peel the two parts apart.
Then use the sandpaper to smooth out the cut edge.
Once you are satisfied with the result, use the second can to gently stretch the lip of the bottom of your stove. This will make it easier to put the halves together. Finally, put some fiberglass in the bottom half only.
Once the bottom is complete, make the top of the can the exact same way, but do not stretch the lip.
The fiberglass is optional, but important. It will prevent the fuel from leaking out while moving it around or while it's in use. It will also preserve unused fuel. Cotton balls will also work, so long as the inside of the can doesn't get hot enough to burn them - a possible concern during stove use or preheating.
7 comments
Jan 31, 2008. 12:54 PMPyroMaster007 says:
yeahh, this is confusing. I think you need to rewrite part of this. Is the Fiberglass needed?
Oct 8, 2011. 6:32 PMDanthesoccer says:
Anything that can serve as a wick.
Mar 3, 2009. 7:39 PMknowlj says:
I guess I'll be the first to say that cutting an aluminum can with a razor blade is a pain. I made the 20 rotations patiently with the razor blade and only managed to etch the can. I then took a dremel to it and in 1 pass the can was cut. I'm trying to figure out how to make a cleaner cut.
Oct 8, 2011. 6:31 PMDanthesoccer says:
I usually make an ugly cut in the can with a razor blade about a cm above my line for my final cut. And then I do the rest of the actual cut with a simple scissor.
Jul 2, 2009. 6:17 PMsbrown says:
No, you use the blade to score the can. You jab the blade through in one spot, and squeeze the top of the can and it will tear along the line
Mar 11, 2009. 1:51 PMezarate says:
what I did is used the razor blade to make a clean line for the cut the carefully cut it out with scissors hey it worked, oh and is it possible to use anything els other than fiberglass? like maybe cotton?
Mar 16, 2009. 3:13 PMbylerfamily says:
You could use cotton.He even mentioned it as an idea.
Jan 30, 2009. 8:09 AMRhysMo says:
The book tip is a great way to get the parts the same hight The fibreglass is to soak up the fuel - cotton wool or something like that is also good. Think of the padding in a zippo type lighter.
Feb 9, 2009. 11:17 AMblakeredfield says:
SNAP. Nice one. I've been trying to figure out what the fiberglass/cotton is doing in there. I have a zippo lighter - should of made the connection earlier! Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
96
Author:NK5
