Introduction: Cool Mobile Charger
Picture of Cool Mobile Charger
Ever needed your mobile to catch a pic or share something and just then your battery runs out. Recently I was checking out of the ones on eBay (see pic)  for portable or external mobile chargers and just realized I could make that ad started to build one. At the end I realized it wast so hard and it cost me around 10$ while the orginals were around 30$. And also looks quite like the one on ebay as in the pic.
In this tutorial Im going to show you how to build a simple portable mobile charger. This has a USB output so you can you can plug in various types of mobile phones. So you can stop searching for a charger and start sharing. More ever this is portable and can fit in ur pocket easily . This charger gives a constant output of 5v at 1amp.
Step 1: Parts
Picture of Parts
1) LM7805
2)USB input pin
3)Rechargeable 9V battery
4)A case to get all of this in.
5)A switch
6)Power input pin (see the pic)
Step 2: Circut
Picture of Circut
Follow the circuit  build the voltage regulator. Insert the switch in between the input DC positive, to turn off the circuit and save the battery . The other pin of the switch goes to the charger .
This gives us three modes of operation one internal battery charging , off and then an USB charger .
Step 3: Battery
Picture of Battery
For the battery I used old rechargeable mobile phone batteries which are rechargeable. I used two batteries connect in series which gave me 9V output. You can go with easy ways by using 9V rechargeable battery which comes with a charger. And for the case you could go with an  altoids container . To save space You could remove the capacitor , but if your mobile keeps on beeping then add it.
celalboz (author)2013-11-18
which of the 3 contacts are the wiring of the battery, two on left one on right? this type of batteries has 3 contacts, which two did you use?
great feat, thanks for sharing
astral_mage (author)2013-10-17
hey wheres the switch go in ? i think u 4got that 1 part?
About This Instructable
2,306views
24favorites
License:
Bio: Hi, I just launched an Indigogo campaign support my projects by backing it. https://www.indiegogo.com/projects/tinker-usb-a-wifi-based-badusb#/
More by ThisIsSteve:Linkit One Text to SpeechLinkit One Kitchen TimerIntel Edison Talks to Linkit One
Add instructable to:
