You will need:
a old speaker ( big enough to fit your portable DVD player into)
a portable DVD player with a line in cable
sticky back plastic with a colour or pattern on it
screw drivers (of different sizes for the different screws)
a drill
a jigsaw or hacksaw (jigsaw will give a neater cut)
scissors
white board marker
hot melt glue gun and sticks
Stanley knife
and finally a working pair of hands
Remove these ads by
Signing UpStep 1Step 1
Either black paint or the same black vinyl.
You can fold it against the edges when applying to the front like wrapping a present.
No, seriously though... Make sure your speaker matches the impedance of the unit's speaker, or you could be setting yourself up for disappointment.
I would suggest, instead, junk a pair of headphones, and wire that jack to the speaker(both Right AND left, to the single speaker). Most portable dvd's have built in limiters for the headphone jack, so you're less likely to cause the internal amp to blow or burn. If you find it's not quite up to par... consider adding a Altoid Amp
