loading
Step 1: Materials
1-40 of 265Next »
Like to see how he made this, but cant find images
mattccc1 year ago
found the instructibile on the web archive with images
http://web.archive.org/web/20100828162104/http://www.instructables.com/id/Copper-Fire-Log-Heater-Burns-clean-with-alcohol/
Morana2 years ago
There are no steps anymore. What happened? Just header, table of contents and comments. Where is the content?
nepheron (author)  Morana2 years ago
I am very sorry, but the content of the instructable is gone. It's a long story, entirely my fault. It was not able to be restored by instructables staff. I might eventually make a replacement.
Please do!
This is one of my favourite ideas!
shascho1 year ago
If anyone still has this instructable
it would be great to see it re-posted!
cant see the picts...
zappenfusen3 years ago
Sounds like a great project. Why am I getting nothing but blanks for pages? Everything but the actual photo's. Anyone have an answer or cure? Have I been banned? My payments are auto deduct, what gives?
Zappenfusen
i getting the same, starts you wondering about the intrisical values of the website.
it's still not working? should fix it.
ckgarside3 years ago
Couldn't you use pearlite as the other 50% of the mix in the chamber to help evarorate the alcohol. I use that method for all my homemade burners and it lights up first time, no preheat required :)
_Scratch_4 years ago
I tried to make this, but didnt use copper end caps, just crimped the ends down... I failed horribly and almost burned my house down. I filled the log with acetone and lit it, but it turned out the crimped ends didnt seal, so acetone leaked everywhere, then the cap I used to fill it spilled, catching the plywood workbench I was working on on fire. So at this point I was scared out of my mind, so I took a spare rag, hoping I could snuff out the fire, but the rag soaked up the fuel and caught fire. I now had a flaming workbench, log and rag that I was swinging around, which incidentally caught the bottle of acetone on fire. I managed to blow everything out before it caught on the surrounding flammable objects, but it was rather close.
let that be a lesson to everyone... DON'T crimp the ends down!!!!
Even better, right next to my bench was a entire cabinet of chemicals, flammable ones.
Quinn Z.4 years ago
were is this thing
itsthatsguy5 years ago
i wouldn't worry about explosions, if the pressure got to hot then the cork would blow out (much like a spud gun) and leak flaming alcohol on the surface below =)
lol
Slicerr24 years ago
you can find here
http://www.sustainlane.com/reviews/how-to-make-a-copper-fire-log-heater/A4PWASUPRVANIR1HKQKU9DIQ2C9O
coppeis4 years ago
Your Instructable is broken
nepheron (author)  coppeis4 years ago
It's should be back online in a week or two. Sorry!
It's 2011, do you know where your 'ible is? I don't see it here. Nice headers for the steps, though.
nepheron (author)  bryan31414 years ago
The file is gone. I'm unable to delete this ible. Sorry.
your instructable is not been working for weeks
nepheron (author)  theexpert4 years ago
Hmm, I'll ask an admin.
I want it to be fixed! I want to make one for the holidays!
nepheron (author)  Saturn V4 years ago
I'm waiting for a response from an admin.
If you have any direct questions about the project, ask away! :)
im still having problems with it and i really want to make it all i can see is 1Matrials
I don't have any questions, but i do have something to say about it: This is a great idea, and it loooks really cool. I can't wait to make it!
Thanks!!!
meister4 years ago
What happened to this instructable? Nothing is here
rokkit6 years ago
is there anything i could add to the fuel to change the burn color?
nepheron (author)  rokkit6 years ago
I've thought about it before. Because it burns via alcohol evaporation you would need a colorant that evaporates with it. Probably non-existent v('_')v
Frag nepheron4 years ago
if you search the types of salts used in fireworks you probablly could find one that, if mixed with the alcohol, would burn similarly.
jrh065 nepheron5 years ago
 A bit of table salt should make the flame more visible, but other colors may be more difficult to achieve.
Boric acid for a deep green color. You can also use borax, which gives a more yellowish green.
Food Coloring of some sort in the Alchohol?
Munchys4 years ago
Can I use lighter fluid?
nepheron (author)  Munchys4 years ago
No, lighter fluid will probably be a very bad thing :)
It could explode!
boehmap5 years ago
What is the mat made of? Where can I find one? Thanks, great project, by the way.
nepheron (author)  boehmap5 years ago
The mat is a rubber mouse pad with the decal removed. Its special because it appears to be made of aerated vulcanized rubber or silicone. It will not melt and will only burn at high temperatures (I have burned it before. It does not release smoke, the foam structure just collapses)
1-40 of 265Next »
