This instructable is about making a shielded copper box.
ELECTRONIC Brief
A photon from a rare photo multiplier tube feeds a narrow pimple pulse into the single input gold BNC connector.
Inside the double electrostatic shield resides a +- regulated supply see the last two pictures and the delicate electronics high speed video amplifier / integrator construction in progress.
The noise generating LEDs come on long after electronic photon integration is complete and differing output signals were sent to the silver BNC connectors. LEDs are to indicate signal processing success of critical stages which may or may not happen.
CONSTRUCTING a Copper Metal Shield Box
Substrate :
The PCB material was easily sliced with a big paper cutter into the shapes for the outside six sides. Then place together four sides and tab solder inside edges for a preliminary fit. Making sure the large base plate see pictures 1 & 2 the top and pictures 3 & 4 the bottom is square with each side.
If a side is off (not square) you can un-solder all but one of the tabs which lets you easily flex the material to square on the loose end and tab solder it in place. Now un-solder the last one tab and see the side easily square-up. Tab solder this end add several more tabs for a good hold.
Place the short sides in square position and tab solder them in place This is the circuit attach copper substrate for the electronic fast video amplifiers.
Cover :
Solder tab the remaining cover plate and side see 3d picture and test fit. Trim the in sides and solder tab to a snap fit.
Close Edges :
Begin solder runs from tab to tab. This is IMPORTANT, Do Not make a continuous solder run (it can buckle your box) as the solder shrinks on cooling.
Instead solder between every other or farther tabs so you have dispersed solder run sections (much like a car wheel bolt tightening sequence).
Ultimately the inside copper should be full continuous solder run.
About Solder :
Hospitals, the military and I hate
Install Battery sockets :
Layout the battery component position and mount it see picture four. Avoid shorting the outside to inside shield by copper rim removal. I use an ohm meter to verify.
Cut and prepare a battery and regulator shield to the cover see picture three.
Input / Output :
Finally decide on your intended circuit real world connections and drill some holes for access. It is best not to short the shields with a connector body.
Almost Done :
You can use a 6-32 hex-long-nut to soldered into corners to latch the cover, see the last picture.
NOW :
You can place or build your electronics in the shielded copper box...
Visit Our Store »
Go Pro Today »
A
Especially near a warfare air force test range.
Thanks for the nice comment.
A
There was a blurb about a 24/7 loudspeaker radio in someones attic 2 doors
away from a transmitting AM station :-)
Those were the days :-|
A
Bob Pease of National Semi. is a great devotee of this construction method.
Its rather pretty too. !
I loved his design puzzles....
I read a lot of Bob's output.
This, was picked-up from an old friend.
Also used the 5 core solder from England whenever I could find it.
A
Had a vote left, gave it to you, liked your red bird on green vine.
A
