Step 6: Construct Base Legs and Pan Support Arms
1. Remove the sharp pointed ends of all (6) Pipe Wire Hangers. Cut about 1/4" off each end with a hack saw and lightly file the ends to smooth (two ends per hanger - twelve cuts total).
'Important: Make sure to remove the same amount of material from all hanger ends so that length of all twelve ends are the same.
2. Set aside (3) of the hangers at this point. They are the Base Legs and are complete as is.
3. Bend the remaining (3) hangers as shown in the bottom photo to form the Pan Support Arms .
The lengths, and angles are approximate. For each hanger, the resultant angle between the large looped end and the two short ends should be 90 degrees. The goal is to have the large looped ends horizontal (to hold a pot or pan) when the short ends are inserted vertically in the stove top.
Important: It is critical that the lengths and angles of the bends are consistent for all three hangers. You want all of these parts to be as identical as possible to ensure that a pot or pan place on the stove is level.
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
