3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Copper Pneumatic Air Cannon
How to create a powerful air cannon from copper pipe and fittings, for very little in the way of cash.
Step 1Materials
Materials
Materials
1.5m (5ft) of copper pipe
One 22mm elbow
Two 22mm endcaps
Two 22mm elbows
One 22mm Ballvalve
One tire valve
Solder
Flux
Ammunition
All pipe in this project can be any diameter, however, as the pipe size increases, so does the bill .
A good chamber:barrel ratio by volume 1:2, however you can change this to suit your needs. A gun with a barrel which is either too long or too short will not be more powerful, but rather less. You can use the Gas Gun Design Tool Tool to find out this length. The ".GDT" file is the saved data for my gun.
As a UK based user getting copper is simple. Many plumbing and hardware stores stock it. I highly reccomend BES Gas and plumbing supplies. I suspect the situation is similar in the US. Ballvalves are very common, and can be bought from most plumbing stores.
Flux and solder will more than likely be available in the same store.
A tire valve can be got from any auto store, or ebay. I got 10 snap in tire valves off ebay for �3 posted. nd they are perfect for this project.
mini1co2.gdt475 bytes
43 comments
1-40 of 43next »
Jan 22, 2010. 5:20 PMstruckbyanarrow says:
did you sweat the pipe together?
Jan 22, 2010. 6:39 PMstruckbyanarrow says:
i didn't know soldering or sweating would hold pressure. will try in the future!
Jan 23, 2010. 10:19 AMstruckbyanarrow says:
wow, thanks! i am looking forward to building my next cannon!
Jan 20, 2010. 7:56 PMflashanimator says:
If i were to make something like this, i've made pvc air cannons before, could you take a 1/2" piece of copper pipe about 1 or 2 feet long, put an end cap with the tire valve on it, and on the open end just use either A) a ball valve and another piece of pipe for the barrel, or B) use a coupler and reducer to make the barrel even smaller, or bigger.
So the design would like -----------OOOOO-    with the dashes being the barrel abd the zeros being the air chamber and last dash being the valve. Also could you use pvc cement to join the pipe together or do you have to solder it.
Oct 1, 2009. 10:18 PMdeNZil90 says:
Would Mild steel work or is it best to use copper piping?
Oct 2, 2009. 2:15 AMdeNZil90 says:
welding is not going to be a problem just wanted to make sure that its going to be safe thanks
Apr 13, 2009. 9:26 PMskimboarder33 says:
is coppper safer than abs?
Apr 11, 2009. 12:50 PMMJRSnyder says:
how do u attach the valve at the back?
Dec 1, 2008. 8:16 AMLED master22 says:
i ment PVC ball valve and not OVC
Oct 21, 2008. 5:05 PMBugman9 says:
iounce shot my airgun at my bike 50 feet away and it came back at my head and got me.
Sep 20, 2008. 1:16 PMi wanna do that says:
ermm i have a question, i live in the uk and i cant find pvc ball valves at all, firstly can a metal ball valve be used on pvc piping and what glue did you use to stick the bike valve to the end cap? Because i am thinking of jus making a simple staright cannon(chamber with end cap woth the bike valve on it,which leds to ball valve which leds to the barrel) thank you and write back please
Sep 21, 2008. 2:20 PMi wanna do that says:
yup helped a lot....so it is possible to use a metal ball valve on pvc piping then
Aug 3, 2008. 7:11 AMafrodude99 says:
good work keep it up
do you like mine my copper cannon
Jun 14, 2008. 12:01 AMryanohal says:
isn't it awkward to fire
May 15, 2007. 6:39 AMbinnie says:
how about joining them via sweat welding?
May 16, 2007. 3:33 AMbinnie says:
uh plumbers sweat weld the joins they do heat it all up then little 'solder' and a capillary action sucks it all in or sumfin like that
Mar 18, 2008. 11:55 AMn0ukf says:
It's just a difference in terminology for the same thing. Though "welding" is the wrong term in this case since you're using a different metal (alloy) to join the copper. For welding, you'd need to melt copper to join the copper pieces together.
Nov 27, 2007. 12:30 PMmonkeybiker24 says:
thank you, my cousin also made one, but better. You can see it at
http://www.youtube.com/watch?v=N8L4iVazozs
and him shooting it at
http://www.youtube.com/watch?v=A0pX_-v_Jbs
Nov 26, 2007. 5:17 PMmonkeybiker24 says:
i didn't use this DIY, but i did make this air cannon, it's the exacte same idea, just remodeled different. Take a look, you can swap barrels for different diameter sizes, i used a bit of ABS for more air room.
Jul 13, 2007. 7:23 PMdogfighter 45 says:
do you think a wider berrel would make it work as a paintball mortar
Feb 18, 2007. 12:30 PMuvalacrosse says:
do you have to use a blowtorch or can you use cement or superglue?
Feb 12, 2007. 4:34 PMlemonie says:
What are you pumping this up with, and roughly how much pressure do you achieve? Your reservoir is small, any thoughts on adding a tank to this?
Dec 25, 2006. 6:45 PMiamcroweman says:
What would happen if you shot flour like that over a campfire. something maybe best done remotely
Dec 24, 2006. 1:47 PMirwinner says:
ball valves open really slow, make it a piston valve, or atleast make the ball valve spring loaded, i t will GRAETLY improve preformance
1-40 of 43next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Biopyro
