perfect for steampunkery or general jewellery.
you will need a 1and one half foot (approx) length of copper wire, about 1mm in diametre and certainly no less.
about 3 feet of thinner copper wire, from transformers ( i would give precise instructions on how to dismantle them but i should think they differ quite a bit. i used an old knife and cut away the glued together plates that formed the core until i could get at the wire)
Some translucent plastic, from say, a bottle of something fizzy
a swiss army knife
a pair of pliers
in this instructable we shall be making the piece with the green tint. it would be a full set of specs but unfortunatley the wire was too brittle on one side and i had to cu one half loose. keep in mind the processes for making a straight set of specs and a monocle thing are essentially the same except that you have an extra side on the specs.
Remove these ads by
Signing UpStep 1Bending the frame
Have you tried heat-treating the thick wire to make it softer and less prone to snapping?
OK it might make a nasty-smell, but blow-lamp, outside?
L
