Introduction: Copper IPad Stand
Picture of Copper IPad Stand
I have seen other iPad/tablet stands made from copper tubing, but didn't like the finished look. This is a very simple project and fits the iPad mini and larger iPads. The actual design, like so many of the things I do, evolved, hence no drawings or proper plans.
Step 1: Parts List
Picture of Parts List
All parts based on 15mm pipe and fittings.
Fittings:
2 x m/f elbow
4 x equal elbow
6 x equal tee
2 x endcap
15mm pipe cut to following lengths:
4 x 20mm
2 x 30mm
2 x 65mm
2 x 72mm
1 x 78mm
2 x 115mm
1 x 120mm
Glue / Solder
Step 2: Create Sections
Picture of Create Sections
To begin the build, I initially constructed the main sections. This simplified the final build and should help in getting all the parts positioed correctly.
Part A - Assemble the M/F elbow by inserting 20mm pipe ninto socket and then fix the end cap on to this. x 2
Part B - Take equal tee and insert 20mm pipe into branch. then connect 65mm pipe in one of the ends and a equal elbow on to this. add the 72mm pipe ito elbow. x 2
Part C - take the 78 mm pipe and attach tees to both ends
Part D - take 115 pipe and attach elbow. then continue with 30mm pipe. x2
Part E - take the 120 mm pipe and attach tees to both ends
Step 3: Assembly
Picture of Assembly
This is where it gets tricky.... although it is fairly starighforward. I recomend doing a dry build first before committing to glue.
Start at one side and fix B to C (branch of tee), then fix B to E, D to C and E
Sorry for not being more descriptive, but it is easier than it sounds.
Once main frame is done, all that is left is to attach A. I put mine at an angle as it looks better.
Step 4: Enjoy...
Picture of Enjoy...
Allow to dry / set. Clean and polish.
Hope that all made sense. This is my first Instructable and first iPad stand. Not bad for a couple of hours work. Adjusting the length of the 120mm pipe and 65mm pipe will alter the angle of stand.
depending on your skill with at soldering this could be also be soldered rather than glued. you could also consider the pre soldered fittings although you'd have to check clearand on front backets.
ToHate-59 (author)2015-03-13
I am in the process of getting the stand chromed.
Thanks for the great comments. Only recently discovered sugru, have considered using it on base as feet.
projectsugru (author)2015-03-13
Very awesome ible. You could try adding little Sugru bumpers to cushion the ipad, then you couldn't need a case? Bit like this http://bit.ly/19gOh9q (oh and the photo in Step 1 totally looks like metal Tetris!)
This is totally awesome great ible! You could try little Sugru bumpers on the back frame, to cushion the iPad so you wouldn't need a case? A bit like photo attached (oh and the photo on Step 1 totally looks like metal Tetris!)
neopolitan (author)2015-02-21
if you buy a can of clear lacquer to coat, you wont have to polish it every day
ToHate-59 (author)2015-02-20
Just done a quick calculation and obviously bulk buying reduces cost further, but I recon as a one off your looking at about £12.
Not sure of final cost as I already had the elbows. Tees, caps and tubing was less than £10. So probably no more than £15 as a one off, less if you bulk buy.
firefightermeyer (author)2015-02-20
What do you think the cost was on materials?
ToHate-59 (author)2015-02-16
My soldering skills have lapsed somewhat, so didn't want to risk spoiling this. I've seen others using glue so thought I'd give it a go. Really happy with results and encouragement.
Wired_Mist (author)2015-02-16
HA, Awesome :D
I think it turned out better using the glue over solder. There's just something about this that makes me smile :)
Grats on your first Instructable, Hope to see more !
KolosWheel (author)2015-02-16
+1 ToHate-59, it looks beautiful!
appliancejunk (author)2015-02-16
Cool, thanks for sharing.
About This Instructable
7,231views
217favorites
License:
Bio: Aspiring wizard... Influenced by steampunk designs and desire to make things my way.
More by ToHate-59:Han in Carbonite - Scratch BuiltRun-a-way GrootK9 dog kennel
Add instructable to:
