Remove these ads by
Signing UpStep 1: Materials
1 AA Battery
1 AA Battery holder(optional)
1 red stranded core wire
1 black stranded core wire
1 pair of wire strippers
1 Alligator Clip
2 lemons or lemon juice
1 knife for the lemons
1 strainer
1 roll of Scotch Tape
1 small Plastic or glass container Big enough to fit what you are plating
10mm of Solid copper wire(stripped)
If you don't have a battery holder you will need:
1 metal file
Some Solder
1 Soldering Iron
Visit Our Store »
Go Pro Today »
unfortunately the whole quarter tarnished and turned black. don't leave it too plate for too long with out agitating the solution or it will form crystals.
make sure not to contaminate the solution, so no paper or any other metal attached to the cathode
Can it also be done with brass instead of copper?
Always my favorite way! :)
also you can use Cu(no3)2 or copper 2 nitrate solution instead of lemon juice.
I have a question, Why does this work? does It bring the copper from the quarter "up"(on top of the nickel, I believe?)
Would it work for other material / alloy ?
