Step 15Using the stand
Depending on the quality of the camera you may get some pincushion or barrel distortion. This is usually not a problem for me because it does not affect the readability of the text. There are plenty of lens distortion correction applications, if you need to have your image perfectly undistorted.
For fastest throughput go through your originals and get them ready to go first; right way up; in the intended order and stacked in a position with easy access. I sometimes put a small object (coin, blu-tak) on the board in the corner facing me so that the page does not lie perfectly flat; this makes it much easier to pick up the page after copying.
When the camera is not being used for some time I put a business card over the LCD to stop dust. I also have a piece of paper dangling from my lens cover so I don’t forget to remove the lens cover before I start shooting.
A peculiarity of the FZ20 is that you have to unmount the camera to access the memory chip and battery. I have found it more convenient to have a USB cable connected to the camera so I can just run the pictures straight into the computer. It takes longer but it is far easier. So I have all 3 sockets on my FZ20 in service = Power, USB and Remote.
I have also found the stand useful for macro photography, enlarging small instruction books, business cards and saving all those little scrap paper notes with miscellaneous data. I wanted to get the maximum use out of this design so later I might get my daughter to sew up some white rip lock nylon to go over it as a light tent. I made an extra full length leg to occasionally replace the short leg; this will support the 4th corner of the light tent later on.
The copy stand is very sucessful, I can archive about 3000 pages on a single DVD; so far the only “thumbs down” has come from the evicted silverfish that used to live in my office.
Add Comment
