Copycat Pattern Making
Introduction: Copycat Pattern Making
Sew Warm Challenge
Runner Up in the
Sew Warm Challenge
My daughter loved wearing my fuzzy hat so much I thought I'd make her one. I wasn't able to find a pattern quite like I wanted and the ones they had seemed a little pricy. Then I remembered something my mom showed me, instead of buying patterns you can make them using what you already have. This is great for anyone who wants more of what they have or who wants a bigger or smaller version of something they have.
Step 1: Figure Out How It Was Made the First Time.
Determine how the article of clothing was made, this is usually easiest to do by turning it inside out. Make note of what was used (liners, buttons, elastic, zippers, etc) and how much fabric you will need.
Once you have that squared away you can make the pattern, I usually use newspaper because it's free and is similar enough to pattern paper that it works pretty well. In some of the pictures, however I used regular lined paper because it shows up better in the pictures. Measure the pieces, this is easier if you have a sewing tape measure but it can be done without; I lost mine when we moved so I made one out of some scrap cloth marked at 1/4 inch increments. Take your time with it and double check yourself and be sure to start right at the seam and follow it as closely as possible, making note of any curves.
Keep in mind though that this method produces a pattern that is roughly a 1/4 to 1/2 inch smaller than what you are measuring off of because you aren't able to include anything beyond the stitch. To compensate, simply make the pattern 1/4 inch bigger all the way around by marking 1/4 inch bigger all the way around(see picture 7), I usually do tick marks and then go back and connect them because it seems to go faster. I made this for my daughter however, so I left it as is to make it smaller, and you can likewise adjust your pattern to be bigger or smaller as you like simply by adding to or removing from the pattern (see picture 8). In general, sizes go up or down by 1/4 inch for babies, 1/2 inch for children, and 1 inch for adults but somethings won't follow that rule- hats for example since your head grows less throughout your life than the rest of you. For this reason is never a bad idea to take a few measurements from whoever will be wearing the clothing (head circumference, shoulder width, waist size, etc) just to be sure.
And with sewing is best to err on the side of being too big instead of too small since you can always take it in but you can't always add to it.
Step 2: Sew It Up
Use your paper pattern like you would any pattern and pin it together, the only difference is that your instructions won't be written down so you will have to refer to the original garment instead. For this reason you should keep it close by throughout the project.
Before you begin sewing double check your measurements while it is still just pined together and easy to adjust.
Once you are satisfied, sew it together. Since the hat I was copying had an inner lining, I first sewed the inside and outside separately and then turned them inside out and sewed them together and sewed the hole closed after flipping it right side out. At first I wasn't sure how the ears were attached but looking closer I found that they were simply sewn onto the outside (something you can get away with when working with fuzzy material). I also decided to change the ears a little bit; be sure to decide what changes you want to make before you start sewing to avoid having to pick out stitches later :)
Step 3:
Well that's basically it. Of course the item you are copying will vary in difficulty but the method for reverse engineering them is simple. This is a snow suit I made for my daughter that was a little bigger and warmer than the one she had last year; it turned out great and I was able to make it without spending $14 on the pattern(I would have used this one as the example instead of the hat but sadly I didn't think to document it). I hope this is helpful and gives someone a new skill even though it is really simple and plain.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    This is a really useful skill --thanks for taking the time to explain it. I'd love to see more step by step photos of your pattern tracing/ trimming/ resizing process. That's the aspect of sewing I've never been good at since you have to incorporate math :)
    Thanks for the input. I guess I did kinda jump over that... oops. I've just added to it; I hope it helps. I have never been great at math and this method really doesn't use a lot which is one reason why I like it. let me know if anything is still unclear
