Step 4Applying the limo tint
Use 2 pieces of tape (one on each side of the limo tint circle) and pull the tint apart from the clear plastic it is sticking to. Put your tint sticky side down on your lens/plexiglass circle.
Try to get as many bubbles out as possible. If you are using a curved rx lens, there will be 'mountains' of tint. If you use the plexiglass, the tint will lay flat.
Use the heat gun to shrink the tint to the lens. If your tint shrivels up a lot or you don't like the way it came out, you can try again with new tint.
Add Comment
