Step 5Adding the edge/rim to the button
Wrap the snake around the button eye and shape with your fingers.
You should put more of the clay snake on the front of the lens and then pull it toward the rear.
You'll have to keep shaping this with your fingers until you get a smooth edge and a smooth join.
After it dries, I suggest using some sort of glaze or clear paint on the back of the clay to prevent it from coming off or melting if you sweat a lot.
If you could find some rubber rings to fit snuggly against your lenses, I would recommend trying that. Smaller hardware stores sell individual rubber rings of various sizes. It would be perfect if you could find a rubber ring that was cut on the inside so that it would wrap around the lens.
Edit: One thing I forgot to mention - Add a bit extra clay to the back of the button eye if you are using flat glass or plexiglass. Otherwise, the button will hit your eyelids/eyelashes depending on your eye shape.
comment
Add Comment
Add Comment
