Step 3Cobra Weave
Single colored instruction
Both
-Tie the two colors together using a square knot or melt them together
-Put the piece behind the other piece with lanyard knots, equally on both sides (Square knot centered)
-Create an "S" with the piece on the right and then take the piece on the left and slide it through the bottom part of the "S" and then behind the middle and up through the left side.
-Pull tight and repeat.
-I recently saw the Paracord Survival Necklace in which there is a flint inside of the cobra weave. That idea can be easily included in this as well. Just place your flint steel in between the two lanyard knots and continue as if it weren't there. If you make a longer key fob with the flint steel it can easily be considered a Survival Key Fob.
Also I am not certain yet of what the point of showing the green and blue ends within each other, if that is what it is, in the third picture. What happens to that part? and where does the square knot end up?
and if so.. where is the square knot itself?
Sorry I just can't manage to follow.
