Cordic Algorithm Using VHDL
Published
Introduction: Cordic Algorithm Using VHDL
About: Mitu Raj - Just a Hobbyst and Learner
##This is the most clicked, popular link in Google for VHDL implementation of CORDIC ALGORITHM##
At present time, many hardware efficient algorithms exist, but these are not well known due to the dominance of software systems over the many years. CORDIC is such an algorithm which is nothing but a set of shift and add logics used for computing a wide range of functions including certain trigonometric, hyperbolic, linear and logarithmic functions. Thus by just using simple shifters and adders we can design a hardware with less complexity but power of DSP using cordic algorithm . This is the algorithm used in calculators etc.
Step 1: VHDL and Modelsim
Here the cordic algorithm is implemented using VHDL to generate a sine wave and cose wave . The code is synthesizable on FPGA. Modelsim is used to simulate the design and the test bench .
Step 2: VHDL Code for the Design and the Test Bench
---- Guidelines ----
Go throu
Simulating cordic_v4.vhd - The Design
-The input is angle in 32 bits + sign bit ; it can process any angle from 0 to +/-360 degree with input precision of 0.000000000233 degree. When giving input -> MSB is the sign bit and the rest 32 bits represent magnitude .
-The output of the design is its sine and cos value in 16 bits + sign bit .ie; with precision 0.00001526. Please note that the output is displayed in 2's compliment form if the respective sine or cos value is negative.
Simulating testb.vhd - Test Bench For The Design
(1) Input angles and pull reset ='0'. After two steps of simulation pull reset to '1' and " run all ".
(2) In simulation window set the radix of sin and cos signals as decimal and format > Analog ( automatic ).
(3) Zoom out to see the waveform properly.
Step 3: Files Attached
(1) cordic_v4.vhd - Design .
(2) testb.vhd - Test bench for the design .
(3) Document on how to force angle inputs and convert the binary results.
Step 4: Mini-Cordic IP Core - 16 Bit
Limitation of the above implementation is
- Slower because of doing computations in a single clock cycle.
Mini-Cordic IP Core - 16 Bit is
- Pipelined architecture
- Faster - FPGA proven design synthesised upto 100 Mhz clock.
- More area optimised , Lesser hardware.
- Load and Status signals added.
- Suitable to be integrated with processors.
Only downside is lesser resolution compared to the previous one.
Files Attached:
1) mini cordic main vhdl file
2) mini cordic test bench
3) Mini Cordic IP Core manual
4) Doc on how to force angles and convert results
-----Designers-----
Mitu and Roshan
for enquiries, contact : iammituraj@gmail.com
###Total downloads : 69 as of till Feb-13-2018###
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    3 Questions
    Hi, can I get password please?
    Please contact in Mail
    What is the password?
    Hi. Can I get the password for the zip file ?
    19 Comments
    Hi !
    can I get password please of Cordic_V4 ?
    thaknk you !
    best regards
    can i have the password please?
    How can I obtain the password?
    hI. How can I get the password?
    hope you got it
    hope you got it
    can I get the password for the zip file ?
    hope you received in mail
    Yes, Thank you so much
    contact in mail.
    Hello. Could you send me the password for the Zip file, please?
    please contact in mail :)
    what is the code the unzip the file and thanks
