3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cordless drill - Improving the battery
Step 2Assemble the new pack of batteries
Aquire a new set of identically sized batteries. In my case the size is called 'Sub-C'. I got them at BatterySpace.com for $24.00. They come with tabs attached. Carefully assemble the new cells into the same arrangement as the original, and solder the tabs appropriately. Be careful not to short out a cell while assembling it - even briefly! You will also need to scratch the surface of the leads before soldering and put a thin coat of solder on each tab before assembly (called tinning). Re-assemble and test. Be sure to re-use the fusable link that came with the original battery pack
7 comments
Oct 7, 2008. 4:15 AMdcobrien2000 says:
I have a set of 18V Coleman tools that came with 2 batteries. A while ago one became hard to charge and finally the other failed. I could not find replacements anywhere so I was faced with buying new tools (lots of $$). I found this post and then the link about reviving rechargeable batteries, it said that crystals can build up in the batteries and short them out. As a fix it suggested hitting them with a blunt object. I opened up the batteries like this post suggests and then whacked the cluster of batteries firmly with a rubber mallet. To my surprise it worked, they now hold a charge and work great, no new tools!
Dec 4, 2011. 3:46 AMsolaralternatives says:
I wonder if that physical shock breaks the crystals like electrically shocking does. Anyone try this with an unprotected Li-ON cell?
Nov 12, 2011. 4:17 PMsnet says:
I recently ran a cross a Makita 6343D with 2 18v NI_CD batteries and a charger on one of the free auction sites. When I received the drill one of the batteries worked fine but the other wouldn't work at all, even though the charger showed it "charging".
I wasn't too concerned since this whole lot was FREE but after reading this I simply tried cleaning the metal contacts with rubbing alcohol and lightly wacking the bottom of the battery with the rubber handle of a hammer and POOF it started working again and holds a charge.
Thanks again for the great advice! =)
Oct 26, 2010. 5:53 PMfromjim says:
I was about to trash a good Craftsman cordless drill because the batteries would not accept a charge, I was in the process of trying to find good replacement batteries at a reasonable price when I came upon this site, I tried the above tactic, whacking the battery pack hard several times on a block of hard wood, I then placed it in the charger and it began to charge, an hour later I had a fully charged battery, even the weak battery that would take a small charge benifited from this procedure.
Thanks a lot guys,
God bless
Jim
Aug 3, 2010. 5:22 PMcrazyg says:
i will try that:-)
Aug 25, 2009. 8:23 AMwupme says:
Its always surprising how many technical stuff you can fix with whacking it. A wack actually fixed my digital preamp on wich an amp technican gave up... Its also a cool way to fix something.
Jul 18, 2010. 5:03 PM-max- says:
LOL! i once fixed a camera with "lens error" by trowing it at a wall!
Aug 18, 2009. 5:58 AMjeff-o says:
I'm delighted when the fix for a problem is "hit it with a hammer." :D
May 8, 2010. 5:58 AMUnkel says:
In electronics, as well as many other fields of maintenance, when we whack on something to make it work, we refer to this as "Percussive Maintenance...!"  It is and has been a tried and true method for getting things to work!
Sep 22, 2007. 9:22 AMwolfpro says:
Check out this link. http://www.hamradioindia.com/HRI-THEOR/Funda-DC/nicad.htm
This guy talks about bringing back NiCad batteries fron the dead.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:BrianH
