I needed a cordless drill to do some outdoor drilling, but I did not want to spend $200-$300 for a 18v-24v cordless from a store shelf. I got a cheap 6v cordless drill that I up graded by replacing the motor, the circuit ,the batteries; and I made box to hold the 16 C batteries. After the fabrication and assembly, I tested it and found that it was almost as powerful as my 120v AC corded drill from Skil. The price of this project would be $30 for the parts, $8 for the alkaline batteries, $40-$70 for nickel cadmium rechargeable batteries.The price depends on the quality of the drill I started with which would cost around 30$. If you have to buy an inexpensive cordless drill, and do this conversion, it will still be cheaper than an expensive cordless drill.
Please note that the photos are in mirrored image.
Remove these ads by
Signing UpStep 1Tools and parts list
1. soldering iron
2. circle guide or compass
3.solder (I suggest lead free)
4. electrical tape and masking tape
5. screw drivers
6. alligator clips
7. wire strippers
8. small hammer
9. red and black markers
10. drill
11. pliers
12. ruler
13. scissors
14. hand saw
15. file
16. pliers
17. wire cutters
18. super glue
19. volt meter or you could use a battery,
light bulb and wire instead to check conductance
20. drill bits
21.sand paper
22. hobby knife
parts include:
1. a metal or hard plastic box
2. metal sheet (I suggest aluminum)
3. battery holders
4. 24 volt motor
5. electrical connectors
6. insulated wire
7. small plastic box from an adapter
8. steel wire
9. 16 batteries
10. 4 button
11. coat hanger
12. CD box
The 1.4 hp motor it is normally used for RC cars, I got this one at a local hobby store for $10, if you can't find it locally you can get it at http://www.robotmarketplace.com/products/0-HTIM1.html
I found a good source for rechargeable battery's at http://www.cheapbatteries.com/nicd.htm I suggest
that you only use nickel cadmium batteries because they can be charged easily, just supply power of 1.7V multiplied by the number of 1.2V batteries, connect in Series or 1.7x) other batteries need a more complex charger.
The four buttons on the second slide of this page are not the same. The two blue buttons are on when at rest and off when pressed and the two red ones are off when at rest and on when pressed.
This will be explained later .
That's more than enough current to melt those switches your using, my guess is that as with most cheap motors, its not putting out near what its rated at. Probably more around .3 - .5 HP
But still, for a drill that's an awesome bit of power :D
and 16 of 'em can't make over 19 vdc or so ..
And 750w/hp divided by 19 is about 39amps, lots less than 50 .. and its only drawing that much current momentarily/rarely , if it ever does!
And that kind of amperage is a theoretical 'max' but is totally dependent upon the electron source being able to keep up with that demand ..
What happens in reality is that the battery voltage will drop substantially , and not be able to put out that kind of power ( Iexp2xR).
Motor specs are very different from power supply specs!
The point is that your instructable does the job, was well-written, and was interesting to review!
