Cork Bike Handle Plugs
2,062
16
Published
Introduction: Cork Bike Handle Plugs
Ever had to deal with the hassle of an open ended bike handle? Well no more! With this quick trick, you can finally plug those handles before dirt plugs them for you! In this quick guide, we will be making stylish cork plugs that should fit most bikes.
Step 1: Clean the Inside of the Handles
Before you start, make sure that the inside of your handlebars are clean to avoid trapping stuff in them! You can use a hose to get most of the current grunge out.
Step 2: Cut the Cork
Next, cut off the end of the cork to get a flat end (Keep the end, you'll need it later). Then, cut around it to make a rough point. This will allow you to easily fit the cork into your handlebars. Don't cut too much off or your cork might become too small!
Step 3: Fill the Handlebars
Try to get a snug fit for your cork in your handlebars. You might need to shave more off your cork in order to make it fit, but be careful to too shave off too much! As seen in the second picture, you can get a pretty snug fit.
Step 4: Glue the End Back
Here you can take the end you originally cut off and glue it onto the end of the handle. The glue is going to hold the end on in order to get the best results for the next step.
Step 5: Finish It Up
Using any screw shorter than the cork, screw the end into the secured cork. This will keep the cork from falling off. That's all there is to it! An easy fix that doesn't look half bad!
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    2 Comments
    Very nice! An additional unintended benefit of adding the screw is that it should help tighten the inside cork a bit too, by pushing the material outwards from the center. I wrap my handlebars and secure the end of the tap inside the handlebar holes, so I'm trying to figure out a way to make this but have it removable for when I replace the tape once a year or so.
