3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Corkscrew knot
Corkscrew knot
Step 1What you need
what you need
Paracord or any string like objects,
21 comments
Feb 20, 2012. 4:25 PM~•SMART•~ says:
I'm the one who took all te pics for Lil C, hi Lil C!!!!!!!
Feb 14, 2012. 12:22 PMrnorman3 says:
Now, tie this around a log or pole or other circular thing that is not attached to people and you have a Timber Hitch!
Nov 14, 2011. 3:17 AMRobotob46 says:
I'm in boy scouts and we call it a double over-hand knot... I guess there's a lot of names for it... :P
Nov 16, 2011. 8:30 PMsokamiwohali says:
Im an Eagle, HBU? What rank?
Nov 16, 2011. 10:58 PMRobotob46 says:
Star... :) I'm a knots guru in my troop... :)
Nov 17, 2011. 9:03 AMsokamiwohali says:
ah...so you got life to go then ur an eagle...keep at it!! its going to get much tougher but is worth it in the end. I was the knots guru in my troop as well! how funny. if you ever want an insanely good book on knots, check out "The Ashley Book of Knots". it aint cheap by any means (like $80 somethin) but is well worth it. there are litterally thousands upon thousands of knots front and back in that book...its a big book at that too.
Oct 14, 2011. 11:06 PMsokamiwohali says:
Its NOT a corkscrew knot, it is a Barrel knot, and it is used as a stopper knot. it can also be used as a knot that joins two ropes (usually of different size) together.
Nov 15, 2011. 5:43 PMIRSisSIR says:
how would it be used to join ropes together?
Nov 15, 2011. 11:12 PMsokamiwohali says:
its complicated to explain, but you have heard of the fisherman's knot which consists of two ropes parallel to each other and at the working end of each rope you tie an overhand knot around the opposite rope...same principal. its also the same GENERAL principal of the hangman's noose in that you have the body of the rope pulling throught the center of the noose...the only things that sets the barrel knot n hangman's noose apart is the tag end goes all the way through the barrel knot and the tag end on the hangman's noose goes through a little loop at the end opposite of the bight, and the barrel knot is a stopper knot.
Sep 8, 2011. 2:01 PMChili Pepper says:
the knot is easier to pull tight if you twist the paracord in your fingers as you pull.
An additional use (of the triple-loop version) - as you twist, you'll notice two loops are created. Drop those over a post, and pull tight to form a strangle knot.
Sep 3, 2011. 6:24 AMthebeef2 says:
Isn't that just a timber hitch?
Aug 29, 2011. 10:33 AMzazenergy says:
Neato! What would you use this knot for?
Sep 3, 2011. 9:40 AMmrubesch says:
We learned that one in our life guarding class to give the end of a rope added weight making it easier to throw, and also it gives the person something to grab a hold of when your dragging them in
Aug 29, 2011. 12:10 PMiambill says:
Stopper knot
Sep 2, 2011. 4:34 PMMonkeyboy13 says:
I thought this was called a clinch knot. idk I've been fishing too much...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:Lil C
Best friends with Macky D and That One Eegit.
