3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Corn Starch Candy Molds
 Intro: Candy Molds from corn starch
On my first attempt to make hard candy I discovered that the selection of molds available locally was pretty limited. Either the molds were not for high temperature or they were teddy bears or lollypops. So I decided to make my own.
I have seen corn starch mold used for industrial candy production so I figured it was worth a try.
Step 1
What you need:
1/2 sheet tray - to hold the mold
1/2 sheet size cooling rack
Full Sheet tray - help to contain mess
Tape measure
Hot Glue gun
Corn starch - 4 lbs for 1/2 sheet tray
Powdered Sugar
Square dowel to hold the positive shape
Some kind of positive shape that can be attached to dowel. I used 1" jewels from hobby lobby. I'll call them a die as you can use any shape that you can find to make the mold.
Calipers - if you are really a geek
Molten Hard candy - you can find multiple instructables on this topic
I measured the 1/2 sheet tray. It's inside dimensions are 17.25"x12.25".
The dowel is 36" long. I need it to be at least 13" long so it can be used as the 'stamp'. To make it easy I cut the dowel in half to 18"
34 comments
Jan 23, 2010. 6:46 AMmatstermind says:
use legos!
Jan 24, 2010. 9:55 AMdomestic_engineer says:
i was thinking the exact same thing. I pictured a bunch of little leggo guys.
Jan 24, 2010. 10:23 AMmatstermind says:
that'd be cool too, I was thinking lego bricks. (maybe with the holes on the underside for stackable ones)
Oct 23, 2011. 10:12 AMfreakyqwerty says:
These are jellies but close enough.
Oct 23, 2011. 12:19 PMmatstermind says:
if i remember correctly, i was thinking of that when i posted the comment
Oct 24, 2011. 2:15 AMfreakyqwerty says:
You'd probly be able to use the mold for hard sweets.
Oct 14, 2011. 10:09 AMperezm31068 says:
Why does the corn starch not stick/mix with the liquid candy and stay mixed when it hardens?
Feb 15, 2011. 9:21 AMbeehard44 says:
what if you turn the cornstarch into a non Newtonian fluid, put it in the tray, dio your die in, wait 'till it hardens and use that?
maybe it'll be sturdier but the problem is when you remove the candies from the mould...
vibration?
Feb 12, 2011. 7:13 AMBlack Panther Knex says:
Well done instructable.
Dec 22, 2010. 9:57 AMammazur says:
Fantastic! I was having the same problem finding a decent mold, and this will work great. Thanks for posting it. :)
Jun 12, 2010. 4:03 PMshortone says:
Would this work for gummy candy as well? I saw below someone mentioned gummy worms.... would this technique work? Thanks :)
Nov 18, 2010. 11:37 PMdanlab says:
it should work for gummy candy, as this is the method most commonly used for industrial production of gummy candy, pouring the molten candy into the mold would just be a bit harder because of the increased viscosity of gummy.
Jul 8, 2010. 3:16 PMbtheskullcrusher says:
I was wondering if you could use melted chocolate in the mold instead of melted sugar
Jan 23, 2010. 10:16 AMDoctor What says:
 Great!  Could you use powdered sugar instead of corn starch for the molds?
May 18, 2010. 11:25 AMsparkyjs65 says:
Powdered sugar won't work if you are making hard candy.  The heat of the syrup will melt some of the sugar and will distort the original shape.
Jan 25, 2010. 9:57 AMchaosrob says:
I would think that the powdered sugar would might, just a bit, and alter the shape of your mold. I've seen this on one of those 'How it's made/Do it' shows and they use corn starch and after it's sifted they use a little 'food grade' mineral oil and tumble the 'candy' (was gummy worms on the show I saw) and that gives them a shine (and slime).
Jan 23, 2010. 10:54 AMscoochmaroo says:
Absolutely!
http://www.instructables.com/id/Cough-Drops/#step3
Feb 4, 2010. 7:42 AMOlivia says:
I've seen cornstarch used in industrial candy-making applications in a factory and always wondered if it could be done at home.
Apparently it can! You've saved me a lot of my own experimenting and mess making. ;)
Jan 28, 2010. 5:14 AMCADMan64 says:
 This is a great one.  I make hard candy over the holidays the old way scoring by hand.  I'm definitely going to try this.
In step 7 you show a store bought mold.  Where did you find this?  I've search for a plain square mold like you show but haven't found one.  Also, how does the store bought plastic mold hold up to the 300 degree candy? I've been leery of using a plastic mold.
Thanks,
CADMan64
Jan 25, 2010. 9:40 PMSunbanks says:
I am so glad you posted this instructable, it will come in handy very soon! :D
Jan 25, 2010. 8:57 AMfrollard says:
I saw this technique being used to make jelly bean jelly centers - makes total sense now that you show it in detail :D
I LOVE making candy.  This is next on my to-do list.
Jan 25, 2010. 9:00 AMfrollard says:
>> the next step is making a heated manifold to pump the candy into each mold cavity without letting it harden too much.
Jan 24, 2010. 11:46 PMPNEUMONIAexpert says:
Very in an original way.
Jan 23, 2010. 6:20 PMBandaids says:
would this help when making peanut brittle when i have troble getting it off a non stick pan such as using that as a base and then laying the peanuts then pouring the carmlized sugar
Jan 23, 2010. 11:40 AMimpulse94 says:
Excellent!  Just what I needed.  Thanks!
Jan 23, 2010. 3:21 AMRintintin says:
Don't you need to dry the corn starch before using it?
By the way, nice instructables.
Jan 23, 2010. 5:22 AMNinzerbean says:
 Wonderful 'ible!
Jan 22, 2010. 10:23 PMRobFS1 says:
Wow! Very nice. I have always thought this would be cool to do but never knew how.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:sandds
