3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Corner Computer Desk Made with Pipe and Plywood
Step 4Legs and Fittings
Legs and Fittings
I cut all my pipe to length with a basic pipe cutter, nothing fancy. I highly recommend holding the pipe in a vice (though not too tight or you'll dent your pipe).
After the pipe was cut I assembled the legs and bracing (see picture)
  • Fittings tighten down on the pipe with a set screw.
  • You can set the brace at any height, I put mine lower to the ground.
I then turned the bracing over and placed the flanges on the bottom of the plywood desktop And marked where the flanges would go. I then removed the bracing and screwed the flanges into the bottom of the plywood desktop.
After the flanges are screwed in I placed the bracing back into the flanges and tightened down the set screw.
In the bottoms of the pipe I inserted plastic pipe caps. These keep the pipe from scratching up the floor.. very important!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
64
Author:simplifiedbuilding(Simplified Building)
I own a online business that sells industrial pipe fittings (Kee Klamp), PVC (pipe and fittings), as well as unique projects made with these products.
