3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Corolla 2007 ipod radio aux input hack
  • last photo ←
I have spent countless hours trying to find a cheap way to get my ipod connected to my radio with a very good quality link. FM modulators suck, you know all about it. I have heard a lot from others online too. This is my cheap fix that might work with yours too, and im pretty sure that all the interfaces are the same for the internal 1-CD player. Cd changers are even easier and I think I saw a demo for that before too.
TOOLS NEEDED: soldering iron, wire strippers(your teeth...jk), screwdriver
ITEMS NEEDED: long extension cable for headphones, you will be cutting one end off.
if you can find in your garage or somewhere a headphone (male) coupling with an open end, then you are lucky and you don't have to buy one. I just got mine from radioshack its quality and the wires are big and easy to solder.
Sometimes headphone wires will be small and enamel-coated (instead of insulated rubber) and they can be tricky so don't use them unless you are zuper awezome.
SKILLS REQ'D : soldering, understanding your own car's components, understanding basic radio components and being comfortable altering them.
I have pictures from my radio, and you can see how it was done from the pictures I took after I finished and was putting it back together.
It depends on which radio you have, I have the A51813 well thats what it says on the outside
A51813
Model No. 816120-02430
Ref No. CQ-JS7460X
Serial No. MX658147
Step 1Take the radio out
Take the radio out
I have seen other places showing how to take the radio out but all you have to do is take the shifter cover out, you can pry it from the back a little and the front a little and it will come out.
Taking off the heater and shelf middle console only has one screw which is in the center knob(the fan speed).
Taking out the vent part is easy if you shove your fingers on the sides and push while you pry a little.
Main point - Get the radio out
Once the radio's surroundings are removed, it is easy to unscrew the 4 bolts underneath with a long tool that fits and when taking it out or putting it in, you must go straight and slow and pay attention to where it is going, maybe use a flashlight if you can't see inside. Mine had 6 holes because two of the screw sites had additional holes where a plastic spike went. Keep track of the screws because the next step has many more.
94 comments
1-40 of 94next »
May 14, 2012. 6:41 PMpcp_9588 says:
I hope this instructable is still active.. I really need help! So i tried doing this with a Corolla 2006 single cd player. I followed the instructions perfectly, or so I thought... My cd player won't even play CD anymore. It'll say Error 3, then spit my cd back out! What can be the reason for this? How can I fix this? Thank you for anyone who can help.
Oct 3, 2011. 10:11 PMsupra92 says:
Just try to do this corolla radio 86120-02450 its kind of working but i hear the music cd and ipod at the same time, it is also not the best audio quality lot of distorsion is there a a way to stop the cd player ? like a pause button ?
im sure that will help a lot , cd player is working ok
thank you for the pictures
Feb 14, 2012. 10:24 AMddeforest says:
I modded the CD player in my 2005 4Runner the same way. Works like a charm!
Try putting the CD in upside-down. The screen will say "Error" but the ipod will play fine. As far as distortion, try turning the volume on the CD player UP and the iPod's volume at about 60%.
Oct 23, 2011. 3:24 PMleilek says:
I opened my 2005 toyota camry le radio and it is different. Any one tried with success? It is Toyota 86120-AA160 Fujitsu Ten 12200-6350C101. There is a label "Aux in". Any one can guide me? Thanks!
Aug 29, 2011. 8:22 AMbzipf says:
Hey I just did this on my 2007 Toyota Corolla. I soldered everything like you said and I got the auxiliary input to work so i can play my ipod now which is great but now my cd player won't work. Is that normal? Is the cd player no longer supposed to work because I've just "hi-jacked" the audio from it to use for the ipod? Please help.
Thanks!
Oct 1, 2011. 6:51 PMeo'connor says:
Hey the CD player should work afterwards, in fact, everything should. You may have soldiered something together inadvertently would be my guess.
Oct 1, 2011. 6:49 PMeo'connor says:
Great instructions. I had a different model radio. I have a 2004 Corolla with single cd/cassette player, model A56821 so the layout was a little different. I actually soldiered my cables right onto the CD player board. There are pins marked L R and ACOM. There is a tiny bit of soldier on them already so i just coated the tips of my wire with a little more soldier, and then connected the two. If you have never soldiered before, i would highly suggest practicing, since it does take a steady hand. I also had to make a small hole in the corner of the case, since the cable wouldnt fit through the gap. I secured the cable with a lot of electrical tape. Over all, it was a pretty easy project.
NOTE: One huge thing that helped me was watching a video on how to get the dash off. I was able to get the radio out in literally less that 4 mins. Go on youtube and look for instalation videos for aux inputs, and you can find several where they take the pannel off. It really is simple if you just see how it's done. All i used was a tiny flat head screw driver and a 10mm socket with extention.
NOTE NOTE: If you are having to FORCE the pannel to come off, you are doing it wrong. You will more than likely break something. Just fyi.
Sep 25, 2011. 3:39 AMHitsuke says:
I don't see any mention of using solder to connect the wires to the pins. Do I just use a soldering iron to fuse the wires to the pin points?
Jun 29, 2011. 9:57 AMclintwire says:
This worked perfectly! Awesome instructions and idea. It was pretty tough Soldering the wires cause the metal solder points were ridiculously small. And for some reason it was a beast trying to get the stereo cover back on. It works great though and is a cheap way to listen to an Ipod.
Nov 11, 2010. 7:51 PMjacintoalfa says:
i have the 3.5mm extention cable, when i cut it, how do i know or test which one is right, left and ground?
Apr 3, 2011. 2:41 PMrthompson3 says:
I found this info helpful when we did this hack yesterday. For a 3.5mm stereo cord, the pinouts are as follows:
The Tip is your Left audio input (LCh).
The Ring (next contact) is the Right audio input (RCh).
The Sleeve (last contact, near the strain relief and cord) is Common.
You'll want to use a multimeter from the wire to each of these inputs and write down the color of the wire associated with LCh, RCh, and Common.
Also, we traced the inputs from the CD player to the board where you'll solder. The inputs were clearly labeled on the CD players board. Finally, we didn't remove the ribbon connector because it seemed to use just the through-hole mounts (with light-to-moderate force, I couldn't separate the connector). This required some careful soldering, but it worked out okay.
Thanks for this tutorial - I love the sound quality!
Mar 15, 2011. 11:36 PMNaVoronda says:
Works for 2005 Tacomas as well. Thanks a bunch!
Sep 30, 2010. 10:41 AMzitosport says:
I need help with a 2004 Corollas the stereo is a single cd player but instead of having 14 pins it has 17 pins...how do i figure it out tohave the right one?? I tried picking the same ones as in the pic but it didnt work...my email diaz.david75@gmail.com thanks in advanced!
Mar 14, 2008. 5:20 PMRoverTFord says:
Pretty sweet hack man. I tried to do it on my 2005 Corolla (A51814 - 6 disc changer) stereo, an it didn't work. Is there something I should have done different because it's a changer? For instance, I know that in your instructions, there was a ribbon that plugged into the soldering site, but on my stereo's board, there's no ribbon there (although this seemed to be in the identical place you soldered to in yours). thanks homes.
Sep 12, 2010. 7:22 PMalexypagan says:
If it's a changer check this out:
http://chrisminglee.com/2010/06/03/corolla-2006-cd-changer-ipod-hack/
Sep 22, 2010. 2:51 PMzer0vector says:
I just followed the instructions on that site for a 2007 corolla with CD changer. It worked perfectly. Just one note, I believe he says to route the cord through the back of the radio, while showing in the picture routing it towards the front, towards the button panel. FYI, follow what he shows, not what he says. Route the cord through the very convenient hole near the connector, then nibble off a bit of the front faceplate plastic near the edge to get it out the rest of the way. It will become pretty clear when you're in there doing it.
Also, be aware that the CD player can put a lot of stress on the solder connections if you have your wires coming up off the board, so try to solder them in parallel to the board.
Jul 23, 2009. 7:13 PMphilgenius says:
wait. Do i test the pins with a voltmeter or what? I remember reading another comment saying that on the 2005 corolla with 6-CD Changer, pin1 read 1.6v while on while pin2 was ground. comment made by boredpoo underneath a comment by jneal, which included a pic of the exact same board that i have.
Jul 23, 2009. 7:14 PMphilgenius says:
And if by voltmeter, what do i test for?
Jul 25, 2009. 11:25 AMphilgenius says:
Never mind. Tested via voltmeter and found what I was looking for.
For those who have a 6-CD Changer in their 2005 Corolla, the pins to solder should be as follows:
Pin 1 = Right Input
Pin 2 = Ground
Pin 3 = Left Input
On the largest ribbon cable that comes from the CD player.
Jan 2, 2010. 11:53 AMmybreathyourlung says:
 I don't understand the RCH, LCH, GND setup, last I stripped one of those small headphone cords there were only 2 wires encased in there. Is my memory flawed? If I use a thicker cord with a 1/4" jack I know that has L, R and G but I don't want a wire that thick coming out of my dashboard.
Jan 2, 2010. 7:54 PMphilgenius says:
 If there are only two wires, there are three possibilities:
1. You have a mono jack, meaning one channel. If that's the case, either get another headphone cable or solder the input wire to both left and right channels.
2. The third wire is a wrapping of some sort (almost a sheathing -- I could be wrong on this)
3. You stripped the third wire off (happens to me occasionally).
Jan 2, 2010. 7:55 PMphilgenius says:
 The three wire setup is because both wires use a ground, but need separate wires for each side (hence LCH and RCH).
Jul 25, 2009. 11:26 AMphilgenius says:
And make a silent CD to use it.
Sep 12, 2010. 7:21 PMalexypagan says:
If you go to this site, you will be able to make a SILENCE CD this way you don't need to put a CD upside down plus you can name it however you want. I named mine iPod this way it will display the name iPod during the actual iPod is playing.
http://duramecho.com/Misc/SilentCd/index.html
Nov 5, 2007. 7:29 AMdchall8 says:
I'm completely lost. Your pictures are probably good, but I don't know what I'm looking at in the pictures. You described a lot of screws, but don't go into detail as to which ones we are going to be unscrewing when. Then a magical wire appears, already soldered in, and now you can listen to your MP3??? Huh? Oh and there is a cable involved, but I don't know what cable and where it goes. And there is a long headphone jack. Do you mean a long headphone cable? Doesn't something have to connect to the MP3 player? is it the long headphone jack...cable? Would you mind rewriting some of this to explain what you did? This time, along with a better description of the recipe, can you explain the theory. With the theory explained, this Instructable will apply to every radio, not just a Toyota whatever model. Here's an example if I am not being clear...This Instructable will show you how to connect a RJ-97 jack to a car radio so you can plug any MP3 player in from the headphone connector - or words to that effect. What parts do you need to buy (cables, jacks, etc.)? What tools do you need to use (wire strippers, etc.)? What supplies do you need (solder, etc.)? And my FM transmitter works great!! I don't know what you've been using, but your radio patch better be very easy (and foolproof) for me to change from a wireless system to a wired system.
Jun 3, 2010. 8:07 AMchrisminglee says:
Chris -
Don't sweat the unclear criticisms about your clarity. Your instructable was fairly well-written, and included pretty good pictures.
Could it clearer? Yes.
Regardless, can people learn a lot from your work? Definitely.
Thanks to your work, I was able to perform a similar hack on my 2006 Corolla with 6-CD Changer. I wrote a guide on that, which I'll link here because I think it supplements your guide.
2006 Corolla CD Changer iPod Hack
If you prefer not to have any link-outs on your page or you feel like I'm spamming you for clicks, send a note and I'll remove this comment.
Thanks again.
Jan 21, 2008. 8:10 AMperiwinkle1239 says:
Chris, what an awesome hack. I am trying to do this on my 04 Corolla. I was hoping that the circuit board layout would be similar to yours, but it's not. I was wondering, did you actually have the radio turned on while you played with it to find the left and right audio pins? For one, the power and speaker cables in my car don't give me much room to have it plugged in, and then work on at the same time. How did you do it? And two, if you work on it while plugged into the car, you must have steady hands while you applied signals to those extremely small pins on the circuit board. Could you elaborate on how you did this? Thanks, Mike
Jan 23, 2008. 5:34 AMperiwinkle1239 says:
Nevermind I figured it out. Works great! Thanks for the instructable!
Nov 18, 2009. 9:08 AMTABRadi0 says:
seeing as how the author blew his stereo, what would be the recommended inline fuse? 1A?
Jun 24, 2009. 7:24 AMmybreathyourlung says:
 Chris,
We have the same model unit (A51813) and I followed your instructions and seeing as we have the same model, I used the solder points you used. When testing with a CD upside down, it worked, but barely. I had to have the receiver volume and my iPhone volume all the way up, but it was distorted and not very loud (as full volume should be), plus, the sound was one channel only.
Now, where I think a problem lies, is that when I used the wires from headphones, but there are only 2 wires there, a left and right. I didn't solder anything to the common because, there wasn't a wire for it. Is this an issue?
It may sound bad because I used cheap wires, but I want to make sure that not using the common/ground solder point isn't an issue. Because of the cheap wires, my solder points might not be the best, hence hearing only one channel. Thanks a lot though.
Dec 29, 2009. 8:15 AMharnish says:
My 2004 Corolla has the Single CD/Cassette Player/Radio in it. The layout is different than the pictures. However, I was able to successfully perform the mod. Just remove the unit and remove enough screws on the covers to get the CD unit out of the radio (including the heat sink on the back). Remove the CD ribbon cable. You will find RCH, LCH, and ACOM test point labels on the CD PC board right by the ribbon connector. (Right Channel, Left Channel, and Audio Common) Just solder a coax audio cable (radio shack $10 spool)  to the test points very carefully. They are very small, so this is not for a solder novice. I routed the cable out the back of the radio similar to the instructions on this site. I used a panel mount 1/8" stereo input jack from radio shack and mounted it on the right side near the shifter across from the 12V power plug. Note that the MP3 input works whenever the unit is on, including CD, cassette, and AM/FM. You should disconnect the MP3 player whenever you want to listen to something other than MP3.
Nov 19, 2009. 2:20 AMthetimsah says:
i have different model, it looks like yours A51802 but different model . how i find the pins?  i tried 12.13.14.pins  but they have some voltage approximetly 7V. thank you
Sep 13, 2009. 9:31 PMsundeezy says:
Can anyone help me figure out which three pins I should use on an '03 corolla? I'm not that skilled (read: completely unskilled) with a multimeter.
Sep 14, 2009. 9:15 AMsundeezy says:
To add a bit more detail, the model # of the unit is A51802, it has a single cd player and the ribbon comes in and hooks into a plug on the main board much like an IDE hard drive cable to the motherboard of a computer. My email is sundeezy@gmail.com, if anyone could send me some pics of the finished soldering (so i can see exactly where/how the wires hook up) that would be much appreciated.
Sep 15, 2009. 10:18 AMsundeezy says:
actually nm - i figured it out...i was just looking at the wrong side of the circuit board =)
Sep 12, 2009. 2:46 PMCpt. Caleb says:
hey trying to wire directly into my cassete deck so I can have my own ipod hook up, but every time I make a connection into the ribbon cable that plays music I get a nasty electronic buzz that's really pretty high pitched, but in only happens when the ipod is turned on. any Ideas on why and how to fix? and if you've got the knowledge, my cassete player realizes it's not playing a cassete after ahwhile and shuts off, any ideas to fix? thanks
Sep 6, 2009. 11:07 PMbooyau says:
Well after taking over an hour to get the radio out (despite reading these and at least two other detailed instructions out there) and then another couple of hours getting the radio disassembled VERY CAREFULLY and getting the solder joints right, my CD changer and aux input are non-functional. When I plug the power back in I hear a series of noises like the CD changer is trying to "boot", and it keeps cycling like that over and over again. The radio works but the changer keeps making the noises. When I push the Load button, it says "wait"... and then after about 10 seconds I get two beeps and it stays on the radio. I can't believe after all the careful work, it's not working! Any ideas anyone?
1-40 of 94next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:chrisayad
