3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Corolla 2007 ipod radio aux input hack
Step 2The radio dissasembly
  • last photo ←
There are 3 different type of screws. The first are the huge ones for the side harness, take those out first and put the harnesses aside.
The next are the little metal to metal screws, those are the majority.
There is also one more metal to metal screw, but it is for the cd drive, and there are two screws that look different from all the rest. They are different sizes, and need to be put in the right hole.
There are a couple screws on the sides of the radio, on the top of the radio, and on the back there are about 6 that are connected to the metal outer shell. take all of them out and the top part that says open should be opened first, then the sides, which slide straight up.
The cd part is loose and should slide straight up out.
-Be careful with the cable, and unplug it. The images are of it after I soldered the wires, but you can stil see how it fits together.
I used a long headphone jack I got from radioshack and cut it to my desired length and stripped the wires. I played around to get the right ones, and the solder points are circled in the pic.
6 comments
Nov 11, 2010. 7:51 PMjacintoalfa says:
i have the 3.5mm extention cable, when i cut it, how do i know or test which one is right, left and ground?
Apr 3, 2011. 2:41 PMrthompson3 says:
I found this info helpful when we did this hack yesterday. For a 3.5mm stereo cord, the pinouts are as follows:
The Tip is your Left audio input (LCh).
The Ring (next contact) is the Right audio input (RCh).
The Sleeve (last contact, near the strain relief and cord) is Common.
You'll want to use a multimeter from the wire to each of these inputs and write down the color of the wire associated with LCh, RCh, and Common.
Also, we traced the inputs from the CD player to the board where you'll solder. The inputs were clearly labeled on the CD players board. Finally, we didn't remove the ribbon connector because it seemed to use just the through-hole mounts (with light-to-moderate force, I couldn't separate the connector). This required some careful soldering, but it worked out okay.
Thanks for this tutorial - I love the sound quality!
Sep 30, 2010. 10:41 AMzitosport says:
I need help with a 2004 Corollas the stereo is a single cd player but instead of having 14 pins it has 17 pins...how do i figure it out tohave the right one?? I tried picking the same ones as in the pic but it didnt work...my email diaz.david75@gmail.com thanks in advanced!
Sep 12, 2009. 2:46 PMCpt. Caleb says:
hey trying to wire directly into my cassete deck so I can have my own ipod hook up, but every time I make a connection into the ribbon cable that plays music I get a nasty electronic buzz that's really pretty high pitched, but in only happens when the ipod is turned on. any Ideas on why and how to fix? and if you've got the knowledge, my cassete player realizes it's not playing a cassete after ahwhile and shuts off, any ideas to fix? thanks
Sep 6, 2009. 11:07 PMbooyau says:
Well after taking over an hour to get the radio out (despite reading these and at least two other detailed instructions out there) and then another couple of hours getting the radio disassembled VERY CAREFULLY and getting the solder joints right, my CD changer and aux input are non-functional. When I plug the power back in I hear a series of noises like the CD changer is trying to "boot", and it keeps cycling like that over and over again. The radio works but the changer keeps making the noises. When I push the Load button, it says "wait"... and then after about 10 seconds I get two beeps and it stays on the radio. I can't believe after all the careful work, it's not working! Any ideas anyone?
May 9, 2009. 11:51 AM_udo_ says:
I just found this page. I will try to add the iPod input to my 2004 Buick radio using the instructions. I will use the casette input if possible, and disconnect the audio wires from the casette head to prevent downgrading my iPod connection. I will try this method to find the audio connection. 1. Insert a CD or casette, and play it through the radio. 2. Use a sensitive AC meter, I guess about 300mV full scale would do, to probe for the audio being played. 3. Connect one meter probe (usually black) to the chassis (ground) probe with the other for the audio signal. You should be able to tell when you hit the correct pins (left or right audio) by watching the AC meter swing up on loud sounds and go down on low sounds. This method is safer, as someone pointed already out, than applying a voltage to find the correct connection points.
Nov 29, 2007. 10:06 PMXHorntail says:
I dunno how I feel about that man.. Applying active voltage to random pins is a good way to fry your hardware..
Nov 6, 2007. 6:31 AMdchall8 says:
These are helpful. Thanks. And despite what you want me to believe, my FM transmitter works great. i have a 2 gig card in it with music mp3s. I got it back in August and use the heck out of it. Yesterday I used it for about 6 hours. Is there something about these things that you know and I don't?
Nov 13, 2007. 8:23 PMtirituf says:
Hi, I want to ask you what do u mean by signal strength on your ipod nano and 50%. Once you transmit your audio signal there is no signal strength unless it is a radio signal. I want to use your technique in my corolla but want to make sure everything before I mess anything up. Please clarify Mr. Chrisayad thank you
Nov 19, 2007. 8:47 PMtirituf says:
thank you for your reply, I will open it up next week. Quick questions 1. Is it really a stereo line in or it is a strong radio line in? 2. How about those boxes on ebay for 64 bucks where you dont have to solder anything? 3. Does your system outputs any kind of unwanted noise? 4. Does your system outputs noise at different speeds (RPMs)? 5. How much would you rate quality of the output out of 10 with your method? compared to the output of regular car cd player?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:chrisayad
