So after seeing somwehere a design for a lamp that makes light by its perimeter instead that directly, iI had the idea of making the Corona iPod Dock.
The light is provided from an unused solar garden lamp, so if you put it in your house where it receives some sunshine during the day, it will autmoatically shine in the night and will act as a nice lamp too.
It uses only materials you can have around your house, and is designed to be hanged on the wall.
The speaker are homemade, with very basic materials. The audio quality is not excellent, but the volume is good for a small room, given that you can make this dock in 10 minutes, it's not so bad, isn't it?
Remove these ads by
Signing UpStep 1Materials
- Enameled copper wire
- disposable pizza dishes
- glue gun
- unused 50 cm ruler
- spare 3.5mm plug
- copper wires and solder
- the top of an "el cheapo" garden solar led lamp.
-4 Disc Magnets:
3x Diameter 20 mm Thickness 5 mm
Nickel-plated,Magnetisation: N42
Strength: approx. 5,6 Kg
1x Diameter 25 mm Thickness 7 mm
Nickel-plated, Magnetisation: N42
Strength: approx. 12 Kg
ps what's the name of the song
