(NOTE: You may never drink pop again!)
Remove these ads by
Signing UpStep 1What you need....
2. A can of pop.
THATS ALL YOU NEED.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
The minimum current a human can feel depends on the current type (AC or DC) and frequency. A person can feel at least 1 mA (rms) of AC at 60 Hz, while at least 5 mA for DC. The current may, if it is high enough, cause tissue damage or fibrillation which leads to cardiac arrest. 60 mA of AC (rms, 60 Hz) or 300–500 mA of DC can cause fibrillation.
Additionally, from the National Institute for Occupational Safety and Health:
Under dry conditions, the resistance offered by the human body may be as high as 100,000 Ohms. Wet or broken skin may drop the body's resistance to 1,000 Ohms.
Ohm's law (basic electricity) tells us: current = voltage / resistance. Using the above numbers, this makes current = 12 / 1000 (wet or broken skin). This results in a current of 12 mA (0.012 Amps). You'll feel it, but it is a LONG way from killing you. With normal, dry skin, current = 12 / 100,000; a current of 0.12 mA (120 µA, or 0.00012 Amps).
Seems pretty safe to me, just don't suck on the battery cables.
Can you repost it? Thanks.
1. I probably would have taken the battery out of the car first, no matter what method I used.
2. Soda isn't the best cleaning agent. The carbonation and acid will remove surface corrosion, but you're also inviting future corrosion (and a sticky mess). A toothbrush dipped in a super concentrated solution of hot water & baking soda is a good option, or if it's REALLY bad, start with a wire brush - GENTLY.
3. I would be hesitant to spread any type of petroleum products on the terminals that was not meant for an electrical situation. Dielectric grease (the same stuff you would use to lube the horn contact ring that rotates against the terminals in the steering column in your bug) would seem safer ... it's a grease, but it's designed to be conductive, and designed to be used in electrical situations.
Personally, I wouldn't bother spreading ANYTHING on my terminals ... it took THAT long to build up, so I would just add checking the battery terminals to your regular six month or twelve month checklist. You know as well as anyone else with a classic bug that these cars are super reliable, as long as you keep up with the HUNDRED BILLION tiny irritant maintenance checks they require.
Other than all that, I heart your bug. I never was huge on the Super Beetles (hence why mine is a 1300 / standard), but 1973 was the only model year I would have considered owning. Plus, yours is the right color :-)
Even if there is minimal risk of the Dr. Pepper conducting electricity up a stream, would it not be a good idea to warn against the dangers of touching the can against the engine bay when pouring on the terminals? Or do I misunderstand electricity? : /
*I assume that Dr. Pepper/Cola etc. still conducts electricity, no matter how much more unhealthy than water it is.
Some external info;
Electric shock
Health and safety executive
No for that you need red wine.
Car Battery Charged With...
