Corvo Mask from Dishonored by EmpressOfDark
When I first saw the cover art for the newly released game Dishonored, I knew that I had to make Corvo's mask as an Instructable.  Most of the items required can be easily obtained at your local hardware store, such as Home Depot; Halloween stores; and art supply.  It is not recommended that this mask actually be worn since it is rather heavy and cumbersome.  I had a hard time posing with it on because it was so heavy and kept sliding down my face.  Instead, it may be used as a decoration around the home or even attached to dummy draped in a black cloak.  Or just let it sit and be spooky all on its own!  (Corvo tattoo not included)
Step 1: Materials
For this re-creation, you will need the following items:
A full face blank mask
A black half mask
Hot glue gun
Thick jewelry wire
1" Electrical conduit fitting
Black spray paint
Silver, black, and copper acrylic paints
Stipple sponge (optional)
Thin rope
Pliers
Wire cutters
Hole punch
Other miscellaneous hardware items
(NOTE:  I forgot to take a picture of everything I gathered prior because I got a lot of items after I began working on the mask)
Penolopy Bulnick says: Nov 2, 2012. 12:46 PM
Crazy cool mask! You should enter it into the Masks Challenge :)
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
