Step 3First Layer
Resin is toxic, dangerous and can be damaging to many surfaces. Keep it well ventilated, away from kids and pets and on a well protected surface. Epoxy is much the same - it can be dangerous and it's very permanent on may surfaces. All of the products included in this project come with safety labels and it's important to read them. One thing I've done is make a list of the chemicals I work with so that if I ever do have a health problem it'll be easier for the medical staff involved to fix it. That said, on to the resin casting.....
You start working from the front of the light - what is the bottom/first layer now will be the front when it's completed.
Mix up about 1/2 ounce of clear resin (according to your manufacturer's guidelines). You can add some glitter or other cosmic debris of your choice to this if you'd like. Catalyze it and pour it into the mold. Tip the mold around to make sure resin covers all of the bottom of the mold, and it's good to let it get up onto the sides a bit.
Let it harden completely.
If you've decided to add a layer of blue/green/yellow/pearly colored haze this is the time to do it. Mix up another 1/3 to 1/2 ounce of clear resin, and again add glitter if you'd like. Pour it into the mold and make sure it covers the front. Add a drop of each color of dye into it then swirl it around with a toothpick. Keep adding dye and swirling it until you like it, then leave it. Seriously. Don't touch it any more until it's completely hardened. If you start working on this and really mess it up just pour it out into something other container to harden up. The reason you do this now instead of with the first layer is that the toothpick can leave marks on the mold that will show on the front of you light. These are permanent to the mold, and no one wants to hurt their mold.
The LEDs behind dye diffuse and glow, while the LEDS without dye in front of them appear as more of a clear point of light. Your choice is all about the aesthetics.
Here's some telescope info for ya' :
http://members.aol.com/sfsidewalk/cdobplans.htm
http://www.usno.navy.mil/8inchdob.html
http://www.funsci.com/fun3_en/tele/tele.htm
