3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cosmic Light With LEDs Embedded in Resin
Step 5Attach the LEDs
Attach the LEDs
You've come to a bit of a fork in the road, so to speak. At least your first time around do it this way:
Set the mold on top of the pattern. Be sure you know which way to orient the positive and negative sides of the LEDs. Think about how you'll handle curves. I've included a sample diagram for a 90 degree turn.
At this point you are effectively gluing a round LED to a flat surface with the glue equivalent of honey. You'll need some time and patience.
Mix up a bit of the clear 2-part epoxy. Put a drop where there's supposed to be an LED. Place the LED face down. It'll probably tip to the side. Use a toothpick or similar implement to set it back upright. You'll have to do this about 3 million times before all the LEDs are set. There's a good chance there's a better way to do this, and if you come up with it, post it. It's very important that when it's all set up and dried the backs of the LEDs are parallel to the bottom of the mold. Having the back completely exposed is what will allow you to wire it. You'll want a little 'cocoon' of clear epoxy around each bulb, this is what sends the light to the front of the fixture.
Your other choice on how to do this step is to pour another layer of clear resin (around 1/2 an ounce) and set the LEDs in that. This may result in more light coming from the LEDs, but it's also more difficult than gluing each individually.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
202
Author:technoplastique(Technoplastique Blog!)
I'm making something new for every week of 2012. Check my blog to see what I'm working on!
