Cosy slippers from your old woolly jumper by ThePrintPlace
Featured
Step 11: Tip: How to blanket stitch
Blanket stitch - This stitch holds two edges of fabric together and protects them from fraying a little. It is also quite decorative if done neatly.
It is similar to overedge/ oversew/ overcast stitch except that you push the needle through the loop you create before you pull it tight. It is easiest worked from left to right and uses LOTS of thread.
• Secure your thread as before and squashing both layers of fabric between thumb and forefinger, bring the needle up in the gap between the layers. (so it comes out at the top of your seam)
• With your thumb hold the thread down and push the needle through from the back about 1/2cm to the right and about 1 cm in from the edge (or as close as the sole seam will allow) so that the needle comes through a loop you have just created. If the needle doesn’t go through the loop this will end up as an overcast stitch.
• As you lift your thumb up to release the thread, and pull the stitch tight it you can see the loop you have made. If you forgot to go through the loop you can always pop your needle through at this stage.
• Pull tight and your thread should then cause your loop to right angle over it creating the ‘bar’ over the space between the two pieces of fabric and your thread is in the right place for the next stitch.
• Continue round and finish by securing threads as before.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
