Introduction: Cottage Jumbo Jenga
This is a great game that's perfect for outside, or at the cottage. It's also a good way to use up any left over 2x4's that are laying around.
It took us about 20 minutes to cut the wood, which will lead to hours of fun.
Please remember be safe and wear eye protection when cutting wood.
Step 1: Materials
You will need:
- 4 1/2, 12' 2x4s
- pencil
- saw (hand or circular)
- plywood (optional)
We used a circular saw because it cuts faster, but a hand saw will due just fine.
Step 2: Measure and Cut
You will want to cut your wood into 57, 10 1/2" pieces.
This will allow three pieces to be side by side in alternating rows.
We started to stack the wood after cutting it so it would be ready right away for our first game. It helps to keep the area organized, as you go along.
If needed, use a plywood base so it will be flat when setting up your game.
Step 3: Start Playjng
Now that everything is ready, you can stack your jumbo Jenga blocks.
The rules:
Set up all 57 blocks, lay three side by side on top of your plywood base. Lay three more on top at 90 degrees to the ones below and repeat.
Each person removes one block at a time and places it on top at 90 degrees to the row on top.
You can only touch the piece that you are removing.
The person who causes the stack fall looses
