Couch Arm Rest
Published
Introduction: Couch Arm Rest
Hello, I'll show you how to make a nice arm rest to your couch!
Materials:
  • Piece of wood
  • Fabric
  • Contact adhesive
Tools
  • Table saw
  • Table mill
  • Rubber mallet
Step 1:
Select a nice and flat piece of wood and cut 21 pieces of 36cm x 2cm x 1cm
Step 2:
Round the edges with the table mill and finish up with a little sanding.
Step 3:
Clamp all the pieces together, flip the sticks and glue a sheet of fabric in the back.
Step 4:
Now you just need to wax it up and it's done!
It's ready to support your beverages!
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    10 Comments
    what did you use to clamp it together and weigh it down?
    any photos of the clamping/gluing process?
    Did you apply the glue only to the fabric or to both surfaces?
    Thanks
    Both surfaces!
    When u r working with contact cement u need to:
    -clean the surfaces
    -apply glue to both surfaces
    -WAIT for the glue to dry(5 min)
    - press the two surfaces together
    thanks!
    Did you use bar clamps to hold it all together? No issues with the wood popping apart under pressure? What did you use to press it all together?
    What contact adhesive did you use? I've been wanting to make one of these with some old napkins and Super 77.
    Hello, I used Norcola.. It's made in Brazil
    I like that it's flexible so it can fit any arm. If the fabric side was cushioned you could double it as a warm food holder. It would be perfect for those big pans.
    hehehe Nice!
    I like it!
    Might add a little support under it for couches with more rounded arms (to make a flat surface for drinks to stand on).
    Great idea!
