After a lot of searching on the internt, I could not find a decent drawing of a console style kickwheel for making pottery. so I made one. Measured drawings included...
Remove these ads by
Signing Up
Remove these ads by
Signing Up
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Thank you for the great instructions!
I also have pending drawigns for a plate display rack, Bottle shelves, 5 gallon bucket shelves, a plate and tile drying case and finaly a motor for the kickwheel
I'm also wondering what kind of shop I might look for locally (VT) to find a good metal wheel head?
Thanks for putting this instructable up - I'm thoroughly inspired!
I saw a similar plan set right after college and had a copy of them but never got around to building my own kick wheel.
The other plans I saw called for pouring cement into a form which sounded very difficult but do-able. I like yours much better using pavers. you could even get round pavers or edgers and get more weight.
You could even glue down old sandpaper down on the top disk to give some grip to the kick wheel.....
LOVE the set of measured drawings!!! Very clear and will be very useful!
Over all a wonderful instrucable!
(now where to find clay?........)
if you have to have clay shipped- it will be expensive, plan to buy in 1 ton (1 pallette) lots to save on shipping. If you dont want that much clay, find a club in your area, to split the cost-- if there isnt one, why its high time for sombosy to start one...
suppliers of clay are:
www.clay-king.com (best bet, loafer;'s glory, a white burning semi poceline clay)
www.bigceramicstore.com they carry everything
www.arrdvark.com I very much like thier Navaho white, but Bee mix is popluar too.
Lagua run through a distribution networlk of vendors, call them to get a dist in you area. they have a nuber oif very fine clays in all sorts of colours.
(I use Amadore, Electric Brown, Redstone, Big white and Dave's porceline from thier line)
worse come to worse, you can alway grab a shovel and a bucket and do it the hard way... (ahh, snakes, very dangerous-you go first)
seriouly, I pay about 25$ per hundred for my studio clay delivered... and Have been using Aarvark's Navaho white almost exclusivly...
I've also seen a primitive one where they use a wine bottle (with a concave bottom) buried topside down in the ground as a socket for the bottom of a wooden shaft. The upper bearing consisted of a piece of greased leather wrapped around the shaft to hold it next to a support. the kick plate was of wooden slabs fastened criss cross like a cart wheel and the top disk was also of wood.
and that goes for the wedg9ing table as well...
Jeremy
I dont think that would be a problem, though I would stick with black pipe for the stub (support end) of the flywheel. of course your going to need the proper sized flanges etc...(annd) you will need to order the right bearings.. use a caliper to measure the outside diametre of the pipe at the middle..
thats my problem with the 1 in pipe I got, the ends (where the threads are , are actually tapered in,- compressed slightly from when they cut the threads on the machine. so my first measurment was 1 3/16 well under 1 1/4... buuuuut.. no...
the main thing is treat the build like a giant unfinished puzzle... if it dosnt workthe first time, get a diffrent peice or beat it with a hammer until it fits....
well, i bought 1 /1/.4 bearings to start too, but coated steel pipe is just bareley over 1-1/4 and they wouldnt fit. so, another set of 1-5/16 (the next size up and they fit on with a bit of persuasion (hammering)
you dont need expensive ones, get these, theyre 15.00 each..
at the big bearing store, (plus 7.50 for shipping i think, it was 45$ for both delivered
the bottom bearing a 4 bolt flange bearing
http://www.thebigbearingstore.com/servlet/the-78/1-dsh-5-fdsh-16%22-Four-Bolt-Flange/Detail
the wheelhead bearing
http://www.thebigbearingstore.com/servlet/the-16/1-dsh-5-fdsh-16%22-Pillow-Block-Bearing/Detail
onre thing i did though, i had several shafts made up or diffreent lengths, and tested them before selecting the 28 inch one, you may want to do the same, depending on your height.
if you havent seen this here I am working on my finished wheel...
http://www.youtube.com/watch?v=ftuWJnqw394
send me pix of your finished wheel when your done....
im currently working on a smaller "kid sized" version, but im having to worry about pinch points and operator saftey more than I did with the full sized version...
you can email me directly at sgueydan@att.net if you want,
Moose
both bearings are 1 5/16. this size fits tightly on a 1 inch inside diametre plumbing pipe. (there is a error on the flywheel page)
on the sheet plan for the flywheel:
the Sheet dimensions are 8 foot x 4 foot, which is the standard size for plywood. 3/4 inch exterior grade.
on the final skinning page:
Im afraid I fudged this just a bit, there isnt enough plywood to make the front counter from a single peice of leftover wood, it instead was made from 3 seperate peices and then covered with a peice of formica I had lying around.
Ill post more errors as I correct them, and I'll repost the finished images as replacements for the ones here.
here:
http://www.instructables.com/id/Build-a-Country-Pottery-Clay-Wedging-Table/
not that im trying to discourage you, it a great project... post pictutres make an instructable be famous like me(BG)
moose
I didn't mean to belittle your wheel. On the contrary I think it's a fine set up especially for someone with only wood working tools.
http://www.bluecollar-supply.com/
of sacramento
tey sell mettal end cuts, odd shapes and half sheets of aliminiuum,steel, brass, titaniuum, and a lot of other odd stuff. Theyre in scaramento
all of the metal they sell is by weight, I bought a aluminium disk (12in diameter, 3/8 thick (laser cut) for 13.00 after tax (3.00 a pound)
www.bluecollarcupply.com
also, www.smallparts.com lots off odd peices..
if you are going to used dimensional shafting, your well ahead of the pack, as my chioce of plumbing parts lead to about a month of experimentation.
if you need any help, just drop a line,
im currently working ob a pug mill and a smaller, kids version of this wheel...
among all the other stuff im working on...
Moose Makes a fish (candy jar) in 3 parts
http://www.youtube.com/watch?v=ZzdOMqhOFjU
http://www.youtube.com/watch?v=4itLjB7eATg
having neither of those, I iused the tools that I had.
if I wanted to get really fancy, I could use a rasp and turn the edge but oits really not that critical... to be perfectly round... if anybody wants the drawings in 8x10 PDF, just ask.....
moose
