All you need is:
1. an A4 piece of cardboard (I would sugest white, so that you can draw or print on it.)
2. a printer (to print the outline of the box)
3. a pair of scissors
4. glue
5. tape (transparent)
Remove these ads by
Signing UpStep 1Get the Outline!
If you are planning on drawing the cover of your card box, print it the size you want it, without any further complications. THe box i made was made to hold about 60 cards measuring 2.5 inches in width by 3.5 inches in height. So if you will be wanting to change the size, check the diagram below to see what you have to change, according to the size and nuber of cards.If you want to add pics on the scheme you have saved, I would sugest you open it in a document, and add imges to the cover. When you are ready, print it.
The tricky part of this insructable is getting the size of the box right.You should first print a sample copy on a normal blank sheet of paper, the edit the sizes on the PC; then print it on the cardboard you will be using.
Now on for the next step.. THE CUTTING!
comment
Add Comment
Add Comment
