Back in the day one would attach tissue to a model with model dope and then shrink it with water. I have used dope in the past and it is nasty stuff, it smells bad and I'm sure the correlation with the drug is quite fitting. So instead I am going to show you how to attach the tissue using glue sticks and use alcohol to shrink it. This method is not only less toxic then using dope it is also cheaper then dope and it is quicker in my opinion.
Remove these ads by
Signing UpStep 1Materials
- A model, this should be self evident.
-Tissue, I use ordinary craft tissue, also called "Domestic Tissue" because a lot of people swear by Japanese Tissue, just make sure it is the none bleeding kind and also that one side is shinny and the other is dull in appearance for some reason it seems to make it work better.
-UHU Purple glue stick, some people use Elmers or Scotch purple glue sticks but the UHU is the tried and true one to use.
-Rubbing alcohol, used to shrink the tissue after it is attached to the frame.
-Spray bottle, used to spray the alcohol on to the tissue with.
-Razor blade for trimming the tissue.
-Sand paper to sand the model before covering and to trim the tissue with.
-Krylon "Crystal Clear" spray paint to seal the tissue.
The first model I made was a messeschmitt BF 109.
