Covert Altoids Dart Gun by Javin007
Okay, so this is really going to be an incredibly simple build. I was just bored, enjoyed making my last instructable, and decided to see if I could throw something together with (guess what?) an Altoids tin and a Bic Pen. Naturally, my mind went to fire, but I didn't want to start a theme, and I couldn't see the Bic Pen being good for multiple flame related uses. So the next best thing, 'Wonder what I could make that you could put your eye out with?"
And thus, the birth of the Altoids Dart Gun.
Ever have a problem with that annoying neighbor that always borrows your stuff and doesn't return it? Perhaps the office mate that always seems to get the promotions that you deserve when they spend 80% of their day playing solitaire and the other 20% at the water cooler talking about the boat they're going to buy with their new raise?!?! But I digress...
Now, with the use of this new weapon, and some curare (this you'll have to find a recipe for on your own... If found, please notify me) you can take care of these pesky individuals. Or at least put your eye out for spite.
Don't let the simplicity of the build fool ya. This thing has some range.
Step 1: Collecting The Materials
You will need the following:
  • JB Stik
  • Bic Pen
  • Thin copper wire (I used magnet wire.)
  • Wire Hanger
  • Bead (As close to the inside diameter of the Bic Pen as you can find.)
  • Rubber Band
  • Dremel
themoose64 says: Nov 13, 2012. 5:44 PM
Cool I put this in my altoids tins creations guide.
wmiddleton says: Nov 22, 2011. 4:26 PM
Very nice instructable, i might build one if i can find the parts lying around
an extra touch could be a small laser pointer next to the barrel to act as an aiming device. =)
pieman12 says: Aug 10, 2009. 1:38 AM
could you use gorila glue
Javin007 (author) says: Aug 11, 2009. 11:42 AM
I certainly wouldn't recommend it. Gorilla glue pretty much sticks to nothing but human skin (and that it binds to on contact, forever). It takes *FOREVER* to dry, and when it dries, it becomes so brittle the slightest pressure will break the "seal."
I honestly haven't found anything that Gorilla Glue is actually good for, which is why I'm not entering the contest.
mslaynie says: Jul 4, 2011. 7:14 AM
Gorilla Glue is actually a marvelous art medium. It can be drizzled, blobbed, etc onto a canvas or board, left to set up, and then painted to create wonderful movement and texture in a piece.
However, I once found out the hard way that gorilla glue does not work to mend plastic eyeglass frames. Trust me, you don't want to know.
Infinite_minus_zero says: Aug 25, 2011. 7:12 AM
Really? it always fixes my glasses :)
mslaynie says: Aug 25, 2011. 8:28 AM
It didn't bond to my glasses, but it bonded to everything else... the bamboo skewer I was using, my hands, etc. It was... interesting, to say the least!
Infinite_minus_zero says: Aug 25, 2011. 9:31 AM
Hm, wierd. I always use it when my glasses ear piece walls off. i just stick a dab of glue on and set it on a paper towl to dry overnight. then i cant close that side of the glasses, but it works :)
mslaynie says: Aug 25, 2011. 10:58 AM
Do you mean the Gorilla Glue Super Glue or just the regular Gorilla Glue? I meant the original, expanding, wet-each-surface-and-clamp glue. It wasn't good.
Infinite_minus_zero says: Aug 25, 2011. 12:29 PM
im... not sure. I dont break my glasses anymore, but im pretty sure it was just "gorrilla Glue" so... idunno.
Javin007 (author) says: Jul 4, 2011. 9:57 AM
Perhaps they should rename it to "Gorrila Art Medium?" Because as glue, it's fairly useless.
Wyattr55123 says: Aug 7, 2012. 8:21 PM
i fixed a telescope with it and it still holds after two years of abuse
mslaynie says: Jul 4, 2011. 10:20 AM
*laughs* It's possible. But hey, I have a great use for it! :D
Cubie2 says: Sep 13, 2009. 2:58 PM
gotta agree w/you.
Infinite_minus_zero says: Aug 25, 2011. 7:16 AM
It would be col if you could modify it to shoot altoids- then you could put altoids over the piping inside and noone would know!
mitch and sean says: Jun 30, 2011. 6:43 PM
Me like, me want
yeolddingdong says: Dec 19, 2009. 3:45 AM
i want to make this so bad but i cant figure out that pic
chosenangelx says: Jun 13, 2011. 6:05 PM
If i have read this right.. he glued/ puttied a smale wire hook to the end of the gun (shooting end i believe?) which is large enough to hook onto the rubber band, but small enough so the tin can close.
mitch and sean says: Jun 30, 2011. 6:22 PM
Yes very true words there chap
mitch and sean says: Jun 30, 2011. 6:21 PM
Does it have to be copper?
thomasthetankengine says: Feb 23, 2011. 4:18 PM
Hey, a video in high speed of this would be so epic! Only if you can though...
Javin007 (author) says: Mar 10, 2011. 9:47 AM
:) I did look into the cost of getting a truly high-speed camera, but I was shocked at the going rate of them. Some people RENT them (with a technician) for as much as $500-$1000 per DAY. Would have to pass on this one.
offroadmaniac says: Feb 7, 2011. 1:33 PM
I don't get this or step 5.
pokerstud001 says: Jul 21, 2010. 9:58 PM
Erm, where is step 2? Is step 2 where you do something with the bic pen, like cut it open or something? Cause i just don't understand how this would work
xBRAZZMATAZZx says: Jan 5, 2011. 2:01 PM
the bic pin is the barrel
bromanuzak says: Nov 4, 2010. 6:36 PM
did it w/ a dip tin ;)
yeolddingdong says: Dec 19, 2009. 3:40 AM
whats jb stik
Madrias357 says: Apr 28, 2010. 9:43 AM
Epoxy putty.  Effectively, a very strong adhesive.  Easy to find at most hardware stores in the adhesives and glue section.
Javin007 (author) says: Apr 28, 2010. 1:22 PM
Well, more accurately, it's an expoxy putty that can handle heats up to 500 degrees Farenheit.  It's also conductive, so is handy for electronics, too.
Madrias357 says: May 3, 2010. 7:56 PM
If I'm trying to work on electronics, I'm getting the soldering iron out and using that.
Javin007 (author) says: May 4, 2010. 9:11 AM
Sometimes the components are too heat sensitive, or you're just in a hurry.
Madrias357 says: May 9, 2010. 10:06 PM
I cheat and use alligator clips as a rudimentary heat sink.  As for being in a hurry, I understand that.  However, I will not use epoxy putty on a circuit board.
weaponscollector94 says: Dec 12, 2009. 11:31 PM
lol i made something like this, it was sweeeeeeeeeeeeeet!
Colonel88 says: Nov 13, 2009. 5:54 PM
I don't really get the firing mechanism and such, I get the hammer and plunger thing, but not how it cocks and is triggered
Colonel88 says: Nov 13, 2009. 5:56 PM
Never mind, video cleared it up a LOT
toaignika says: Jul 19, 2009. 9:49 PM
wouldn't this be... well... dangerous?
Javin007 (author) says: Jul 19, 2009. 9:57 PM
99% of the stuff on this site would be dangerous if not handled maturely and with some common sense.
Cubie2 says: Oct 4, 2009. 5:04 PM
toaignika says: Jul 19, 2009. 10:37 PM
true
ItsTheHobbs says: Jul 23, 2009. 12:28 PM
Perfect mechanism for a trip wire.
Javin007 (author) says: Jul 23, 2009. 1:43 PM
:D Didn't think about that. The girlfriend will have a bad evening, and I'll let you know how it goes if I can find a way to anchor it.
Cubie2 says: Sep 13, 2009. 3:05 PM
Cruel :) (I'm not laughing and thinking about how funny that will be!)
ItsTheHobbs says: Jul 23, 2009. 4:30 PM
Hehehe.
Cubie2 says: Aug 28, 2009. 6:51 PM
Airsoft bb's are almost the exact diatmeter of a bic pin try THOSE!
tanmanknex says: Aug 28, 2009. 10:24 PM
I bet they're work great! I bet you could use tech classes to make these- "hint hint"
Cubie2 says: Sep 10, 2009. 7:45 PM
hmm... I have no idea what your talking about tanmanknex ; )
tanmanknex says: Sep 10, 2009. 8:28 PM
Just a suggestion for those in school still.
Cubie2 says: Sep 13, 2009. 2:52 PM
I'm 25 and just getting out of the airforce what are you talking about?
Javin007 (author) says: Sep 11, 2009. 4:14 AM
I'm still with Cubie2 on this one...
tanmanknex says: Sep 11, 2009. 5:15 AM
What do you mean?
Cubie2 says: Sep 13, 2009. 2:53 PM
I would be guessing Airsoft bb's
andi456 says: Jul 11, 2009. 11:00 PM
I dont get it
Ananand says: Jul 9, 2009. 2:18 AM
Awesome! I have to try this
Genises says: Jul 8, 2009. 11:09 PM
this is good!!
Tape-structable says: Jul 8, 2009. 12:48 AM
Very nice. I might make this if I get some more tins.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
