3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cozy Low-Energy Shower
Step 25Appendix: Non-toxic waterproof wood finishing
Tung oil is a traditional way to waterproof wood. It's oil extracted from tung nuts that cures when exposed to air. You spread it on the surface and allow it to soak in, and then wipe off the excess. It will still be damp, but if you leave it in a warm place for a few days it will cure and partially seal the wood. You repeat this process two or more times. More instructions, and the oil itself, are available from the Real Milk Paint Company. Note that most instructions are for using it for fine wood finishing. For just trying to make something waterproof, you can be less careful and put on thicker coats. Note that it cures faster if you leave it in a warm spot--I use the top of a radiator in the winter.
If you go with tung oil, note that there are lots of "tung oil finishes" that contain little or no tung oil, and use the name simply to mean it is a wipe-on finish, which may include many toxic ingredients. So be sure you are buying the real thing.
For an added layer of protection, you can add a few coats of shellac, which is a bug secretion applied like a paint by dissolving it in alcohol. Normal shellac doesn't do well in water--it turns white. But de-waxed shellac does much better in water. You can buy flakes of de-waxed shellac and dissolve them in denatured alcohol that you can buy at your local hardware store. Shellac.net sells a wide variety of shellac flakes and has further information about shellac. Unlike many other finishes, shellac sticks well on top of tung oil, at least if the tung oil is fully cured first (which might take a week or two).
I doubt the tung-oil/shellac combination is as waterproof as a good marine varnish, but it's kept my shower pedal looking good through daily showers for at least six months now.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:LowEnergy
