3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Cozy Low-Energy Shower
Step 4A) Enclose the stall: Materials & tools.
You'll need:
1/8 inch Plexiglas (acrylic sheet) cut to a pretty precise size. You can buy Plexiglas at most hardware or home improvement stores; some will cut it to size for you. You can also order it online, cut to size. For example, from Interstate Plastics. From Interstate Plastics, you can specify a tight tolerance on the size (I'd go with +/-0.030") for only about a dollar extra--well worth it to be sure it fits right. You can also cut it yourself. You can scribe it with a utility knife and break it along the scribe line, or you can use a table saw with a fine-tooth carbide blade if you have one.
You could use any light, reasonably rigid material: thin plywood, fiberboard, even cardboard waterproofed with a plastic sheet or paint. But a transparent, or at least translucent, material helps let light in.
Aluminum L extrusion, long enough for the edge that needs support. The exact size and thickness doesn't matter much--mine is 1" x 1" x 1/16" thick. You can buy it at a hardware or home improvement store and cut to to length by hand with a hack saw.
Polyethylene sheeting (drop-cloth material); or other material to cover any gaps. Other materials can be used: You might cut up an old shower curtain, or buy some water-resistant fast-drying cloth such as nylon. I chose polyethylene sheeting because it is less toxic than vinyl shower curtains, because it's clear (you want the shower warm but not dark), and because I had some around. IKEA has a great selection of non-vinyl shower curtains if you want to have some color options without using vinyl.
Binder clips and/or clear packing tape for attaching polyethylene sheeting
Tools:
Tape measure
Hack saw for cutting aluminum
File to smooth edges of aluminum
Scissors for cutting polyethylene sheeting
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:LowEnergy
