Crab Bot, Sidestepping Robot
2,282
18
Published
Introduction: Crab Bot, Sidestepping Robot
About: I am passionate about anything and everything engineering and physics. I am interested in much of chemistry and biology and I enjoy most art and craft + cooking and baking. I have completed my bachelor's in ...
Ok, the title might be a little deceiving, the robot does not actually have claws or does it walk sideways.
But this robot is designed to turn on a dime and be able to move sideways apart from the usual four wheel powered platforms maneuvering.
For this ible i will be assuming that you are familiar with Lego NXT sets and i am just sharing with you what i have learned in making this robot. Mainly some pictures of the mechanisms i use, guidelines and tips
The objective of this project was to build a robot that has as many degrees of freedom as possible on the floor with the minimal amount of motors and NXT(s) used.
You could of cause get better results with omni wheels like mecanum wheels. but this is what i have.
Step 1: First Up, Some Videos
Just a video of it in action
A little narration to show you how the controls are linked to the robot
And the underside
Step 2: Powering Your Wheels
Basically you need the turntable for this to allow your wheels to swivel while having your motors fixed
the pictures below will show a break down of the assemble
It is VERY important that nothing moves except the gears. This is because your gears will be subjected to very high torque (by NXT standards) and if any of the supports come loose, the gears will slip and it will fail.
the gears i used are not very conventional looking and these gears provide good contact as well as smooth power transmission.
the second third gear was used to reverse the direction of the wheels so that the wheels spin in the direction that will not oppose the swiveling action, its a bit hard to explain but you will get what i mean when you try it out
Step 3: Powering the Swivel
In trying to keep to my plan of having 1 NXT control one side of the robot, I placed the swivel motor in the middle of the robot and use gears to transmit that torque all the way to both ends
the key here is to have the gears turn the turntable
Step 4: The 3 Swivel Angles
Here you can clearly see the 3 different angles the wheels can be swiveled to.
For a sample of the programming i used, send me a PM*. (i used NXT-G)
Edit* Unfortunately due to a computer reformat some time ago, I am no longer able to locate the program. My sincerest apologies for this.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Stick It! Contest
      Stick It! Contest
