Cracked Marble Necklaces
388
9
Posted
Introduction: Cracked Marble Necklaces
In this tutorial we will be making cracked marble necklaces that are a great idea for little kids and are super cheap to make.
Step 1:
First you need to get these supplies
1. A marble
2. A paper clip
3. Rainbow loom (if you don't have one you can use string)
You will also need a pan that can be heated in the oven, a bowl with ice water, and obviously a oven.
Step 2:
Heat your oven to 350°F and put your marble in the oven safe pan. Put the oven safe pan with the marble in the oven for 25 minutes. Get ice water ready because you will need it for the next step.
Step 3:
Take the marble out of the oven and put it strait away into the ice water. If the don't crack put them back in the oven (the should crack right away).
Step 4:
Wrap the marble with the paper clip and if you can't make a good enough swirl around it use a marker about the same size as the marble to wrap the paper clip around and then put the marble in.
Step 5:
Align your rainbow loom (or get your string)
Step 6:
Slide the loom/string through the loop at the top and there you have it.
Step 7:
Now pu the marble inside the ice water right as it gets out of the oven it then should crack (if it does not put it in the oven longer it all depends on how the ball was made). I ended up making a bunch just for fun cause I had nothing else to do with the marbles.
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
