http://www.grooveking.com/blog/2006/03/grooveking-geekout-make-your-old-brick.html
http://kamalot.blogspot.com/2005/09/nes-bluetooth-handset.html
Both radioshack and Amazon had the Motorola HS820 on sale for 30 dollars this week. I bought one, popped it open. I wrote this up to show how easy it is and why you shouldn't be afraid.
Remove these ads by
Signing UpStep 1Remove the Ear Hook and screw
1) I'm not sure of the technical name, but I'm going to call it the ear hook as it hooks around your ear. It just pops right off if you give it a slight tug. It's supposed to pop off so you can change the orientation of the set. It turns out that I'm left earred.
2) After you remove the hook, then take out the screw. It's a hex screw but, I found a mini-flathead screwdriver that was able to fit perfectly.
It just looks like a little pad - do you tear it off?
Thanks!
I just w00t!'d two Jabra BT350's (and ordered tiny conical solder tips too...;) and will do an Instructable on tearing it down _and_ soldering leads to a separate board to make it easier to hack onto/into other devices.
