Cracking Open The Motorola HS820 Bluetooth Headset
Step 6Test to Make Sure Headset Still Functions
I atttemped to make a call with the disassembled unit and it still functions. Woo hoo it does. Notice the placement of the led. this could come in handy when you re-appropriate the headset for one of your projects.
8 comments
Jun 11, 2011. 8:31 PMmtdna says:
How do you rewire the On/Off/Call switch for easy hacking? For example, how do you wire it to a separate push button?
It just looks like a little pad - do you tear it off?
Thanks!
Aug 5, 2011. 10:58 AMbeehard44 says:
you desolder the switch and solder wires to the 2 pads
Mar 16, 2011. 8:54 PMThaikarl says:
i opened an much earlier model of one of these motorala jobs. there were these two tiny tiny bits, along the edge of the seam on each side that flew away. i examined the thing carefully, and decided that those were "anti-hacking" bits. if you took the thing apart - i was trying to see if the battery could be replaced - the little bits would fly off, and when you put it back together, it wouldn't work
Sep 5, 2009. 10:11 PMstankdog says:
would it be possible to hook this up to a regular speaker (6x9) say for a garage application. I hate the ear phone but would love to answer the phone. Let me know as I have several types of speakers left over from a wall of sound project! Thanks,
Feb 9, 2009. 8:06 PMairwalker20 says:
hey, just found this headset and tried to charge it, but the led doesnt light up, and i opened it but couldnt find anything( in my unexisting experience ) wrong, ill try to charge it tonight and see if maybe the leds wrong, any suggestions on how to check if its still worth anything? by the way, great job
Oct 18, 2007. 4:46 PMBoss_Sauce says:
Excellent tear-down! I put a Jabra into an old AT&T handset (see the flickr set) but destroyed a second headset-- a Motorola-- trying to solder leads to its circuit board...:( Those components are tiny!
I just w00t!'d two Jabra BT350's (and ordered tiny conical solder tips too...;) and will do an Instructable on tearing it down _and_ soldering leads to a separate board to make it easier to hack onto/into other devices.
Aug 12, 2006. 4:50 PMirritant#9 says:
At least you are done with that flathead screw driver.
Jun 11, 2006. 3:54 AMremarc solo says:
Ylim is right if you are trying to send a lot of data. However to transcieve at say 1200 baud attach either a modem, or implement one using a function in a $5 dsp or microcontroller. (Should use about 10% of the CPU). If a hundred people want it I'll show you how and get the kit.
Jun 10, 2006. 7:01 PMylim says:
Interfacing bluetooth is seriously tedious, perhaps because of the tight requirement of synchronizing the hopping sequence. It is pretty amazing how the bluetooth is selling that much. The point that I am driving is without a proper datasheet, I guess this module is nothing much of a value in serious work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:easement
