Crafty Fidget Spinner - Make the Way You LIke
Published
Introduction: Crafty Fidget Spinner - Make the Way You LIke
About: I love DIY Electronics
Fidget spinner is a stress buster that everyone is fond of, it is a stress relief and overall it makes a fun toy. After the initial design, there are thousands of designs you can find of the fidget spinner, each designed to own personal style.
I like to craft so I had to make a paper version of it, as it is recyclable after use and it is easy to be shaped into anything you want it to be.
So in this instructable, I'm going to show you how to make a Cardboard Fidget Spinner.
Step 1: Things Required
All you need is,
  1. 2 colour sheets (any colour)
  2. Card Board (2cm x 2cm)
  3. Toothpick
  4. Scissors
  5. Xacto Knife
Step 2: Folding
  1. First, you'll need a square sheet of paper, to get a square sheet you need to fold the sheet diagonally from the upper right corner
  2. And now cut the bottom part remaining part of the paper to make a perfect square.
Step 3: #1 Creasing
  1. Take the square sheet and fold it into a half, again fold it in half to make the two corners meet.
  2. Crease the paper as seen in the images till you get lines with which you can work with in the next step.
  3. Next, you'll fold each of the corners down on a diagonal. Make sure that they are in opposite direction.
  4. Next, you’re going to take the points and fold them down to form another triangle.
  5. Now keep the two paper folds in the position as shown in the picture.Now tuck in each corner with the little fold.
Step 4: #2 Fold and Creasing
Repeat the previous step following the images. You can use any color combination of your choice.
Step 5: Blades
  1. Now you should have similar looking mirror image parts as seen in the picture.
  2. Next, make three folds as shown above until it looks like a blade of a fan.
Step 6: Cut Holder
  1. Now take a small cardboard piece and a coin. Cut the cardboard into a round shape about the size of a coin.
  2. After you make a hole in the middle of both the rounded cardboard.
  3. Fix the toothpick piece through the hole made in any one of the rounded cardboard using a glue.
  4. Next, pass the paper fidget through the hole made, fix the another rounded cardboard as shown in the picture with glue.
Step 7: Rotating Mechanism
  1. You need to make a hole in the size of tooth pick right in the middle of the fidget spinner.
  2. Next, pass the paper fidget through the hole made, fix the another rounded cardboard as shown in the picture with glue.
  3. This gives it an even spin and you are now ready with your fidget spinner made out of cardboard.
Step 8: Finishing
Decorating is optional, but it would look better to add some decoration than to just keep it plain.
For decorating I cut out two round pieces of Cardboard and drew a smiley face on it.
Hope you liked this project if you want to see more project check out my other Instructables.
Thank You.
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
