See all those fun infused sprits they have in the liquor stores? They mostly use chemicals and LSD to flavour their hooch. Personally I like the way they taste, but I thought I'd give it a try on my own.
I made a kahlua a few years back, and tried to reduce the recipe to just a 355 ml (12 oz) bottle, the outcome was a sugary liquor headache that I had never experienced before, or would want to ever again. Lesson learned: Scale down recipes properly. 'Eyeballing it' doesn't work for such a small batch.
Anyways, after countless other variations of this and other concoctions I present, Cranberry Infused Vodka.
What you need:
A mess of Cranberries
1.14 Litres (38.5 oz) of Vodka
A big jug (mine was 5 litres [169 oz])
Sanitizer
Siphon hose
Gelatine Finings
Several smaller jugs or bottles to bottle it into
Something to mash cranberries with
A cloth
White Sugar
Cheesecloth
Colander
A large container
Remove these ads by
Signing UpStep 1: Gather
I managed to find this sack of crans at work. I work an office job and I showed up one day and there was a crate of these little guys just sitting there (and no, my job is so far removed from fruit, it's not even funny). So either look under your desk at work, wish, or raid a farmers field for a bunch, however you can get them, you'll need about 5 cups (5.2 cups).
The vodka I grabbed is some cheapie from the store. This tasty bevy is going to be served with other ingredients, so there's no reason to bust out for the Belvedere, but if you did I'm sure you wouldn't be disappointed.
Sanitizer can be found at any wine supply store, or U-Brew place. This is the same sanitizer used for sterilizing wine bottles, carboys, primary fermenters, and the like. I grab most of my wine stuff from Wine Kitz (free plug!).
Visit Our Store »
Go Pro Today »
Your comments:
"What I had done was washed the jars then set them upright in a pot of boiling water. "
and
"the water in the jars didn't look like it was boiling "
concern me. I wouldn't trust it.
I understand why you chose this method, however it's just not practical for most types of bottling. Hot (boiling) water should work, but how awkward is it to handle, are you sure you got every surface, can your boiling pot accommodate different types and shapes of bottles? All very important questions when dealing with sterilization.
You could have some very potential problems regarding sterilization, but maybe not. Using distilled spirits like this has some advantages, namely the high alcohol content which would aid in fending off bacteria. However this is almost a moot point considering the high sugar content used in many steeped drinks which are a food source for wild bacteria to feed on.
The solution for this is to buy some sanitizer from your local brew shop. It'll be a pink powder sold at a reasonable price. You won't need much, just follow the instructions, usually a small scoop added to 5L of cold water will work. An alternative to this method would be to use bleach. yes, bleach.
With the bleach method you will need to be more fussy about rinsing and cleaning but it will work. Mix a solution of 70/30 bleach to water and bathe your bottles in the solution, then rinse, and rinse again until your bottles aren't slippery any more. This method is less ideal due to the nature of bleach being pretty terrible stuff if consumed, but the result is the same. I've also seen an iodine sanitizer, but wouldn't recommend it as the pink sanitizer is easier to handle and less harmful, and the bleach is more readily available. Personal preference is everything, they all work.
I hope I answered your questions and this helps, chances are your brew will be fine, after all you washed and (attempted) to sanitize, and unless you are brewing a beer or wine which requires yeast to ferment you should be safe.
When your brew is finished don't forget to post some pictures here and the recipe you used, that would be awesome!
Gelatin
Gelatin finings are not restricted to low-class drinks, in fact the caliber of your product has nothing to do with using gelatin. It's all to do with the particle count of whatever ingredients you are using. So if you are using raw grapes or berries to make your mixture then you're going to have plenty of particles floating around (which isn't gross, in fact it's natural!).
Actually real clarity is reached in one of two ways, and in many cases both:
1) filtering. I mention it somewhere else in this Instructable, but filtering will increase the clarity of your product. The best method of filtering is a pressurized method which forces the liquid through a filter (Commercial wines use this method, the wine is pumped through a sandwich of filters and comes out really clear on the other side.)
2) Racking. This method is also explained in the Instructable. Racking is a fancy way of siphoning the liquid from one container to another without disturbing the sediment settled on the bottom. The partner of racking is time, as over time your liquid will settle more.
I'll admit that gelatin finings are not mandatory for this. If I had a better filter system I would use it. However this method (like racking) is passive and worked perfectly for such a small batch.
Syrup
"i don't think adding syrup is needed in your recipe; glucose is added to drinks in order to be transformed in ethanol by yeast. But since you use sanitizer in every passage, I doubt there is any in the mix. That's probably why your drink is cloudy and you need to add gelatine."
I think you are getting different things confused here. The syrup used was for sweetener, if this step was omitted then the mixture would be very bitter (cranberries are by nature a very bitter fruit). The alcohol content was not increased by the addition of syrup. The only way that this would happen is if I had put yeast in the mix (which I did not and is not mentioned in the article). Also yeast only works up to around 14% ABV, then the mix becomes too potent and kills the yeast, to achieve higher alcohol by volume you will need to distill, but that is a different Instructable altogether, so I chose to use just straight vodka instead, hence the title "cranberry infused vodka", not "distilled cranberry mash".
Thanks for the comments markvid! These are some very fine points which may have been lost on the kids sitting in the back row. Have you made some infused drinks of your own? I'd love to see them, post some pics!
I've got a few more recipes I'd like to try out. In America they have Everclear which is pretty much ideal for using in recipes like this, however our Canadian dollar is less than attractive for me to make a trip over there right now.
Those crafty Americans don't let us have any fun :(
I am going to make the vodka, and want to serve it in these.
http://www.cooking-gadgets.com/edible-candy-cane-shot-glasses/
Anyone have an instructabe for making them???
http://wiki.answers.com/Q/Does_rubbing_alcohol_kill_germs
