Introduction: Crazy Gourd Bird
This bird was created from multiple home grown gourds.
Step 1: Materials
An interesting collection of gourds
Hot glue
Dremel cutting tool
Wood dowel if needed
Acrylic paint
Paint brushes
Coat hanger (wire)
Paper clay (optional)
Scrap cloth
White Glue
Drill
Pliers
Step 2: Pick Out Gourds
This is the fun part deciding what gourds to use. Some gourds can be cut so you just use a part of the gourds. The top notch is cut from the same gourd I used to make the wings. The wings are cut from the side of the gourd using a Dremel cutting tool.
Step 3: Glue Gourds Together and Make Coat Hanger Feet
Gluing the pieces together is when the bird starts to take on it's personality. You can use pieces of wood dowel to hold some of the gourds together. In this case, the legs are made stronger by using the dowel. A drill can be used to make holes for the dowels. Wire coat hangers were used to form the feet. Another small hole was drilled at the base of the legs and the wire slipped into that hole and glued.
Step 4: Finish Off the Feet
Long strips of scrap cloth material were covered with white glue and wrapped around the wire feet. Once the material is dry you can add some paper clay to give the feet more shape.
Step 5: Paint
This is where you can go crazy. Acrylic paint works great. Try different techniques to create feathers and different textures. Once you are done painting you may want to coat it with a matte varnish.
Crafting 101
